failed to unlock F480I. any help? hello, I use SAMSUNG 2G TOOL V3.4.0034. CABLE J750 WHEN PRESS DIRECT UNLOCK selected model:f480i selected com port:com91 selected speed port:921600 please, connect phone and press 3 sec power button timeout send loaders-fail unlock - false elapsed time: 34 second, sw ver: 3.4.0034 |
Bro just connect ur phone in Qualcomm mode type *#782872# thn connect Org USB cable with ur handset . thn u can see Found new Hardware on ur pc then install QualComm drivers c:/program files / Z3x/Samsung/Qualcomm after install the drivers check in device manager modem port of ur mobile then select port where u select port 7 . then try again hope your problem will be solve . |
now direct unlock test by me cable rj45 |
U hav to use e210 cable which come with the box |
Phone must be off - F480I - broadcomm. |
hello bro chek correct comport good cable insert cable without battery when soft go to job put battery enjoy br ;) |
give it a try once more have done this model before bro |
1) insert cable and connect mobile without battery 2)click on "Direct unlock" button 3)wait for this log given below "Please, connect phone and press on 3 sec power button" put battery back to phone Don't press any key including power button. Selected model: F480I Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press on 3 sec power button Booting... OK Found bad block Remaped bad block 654 -> 1002 Unlock - ok Elapsed time: 43 second, sw ver: 3.5.0032 |
