Old 02-14-2008, 22:50   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
FAQ: Activation, Driver, Card problems. Read this before use BOX!
ATENTION! Box is not activated while shipping.
DON'T ASK IN FORUM ABOUT ACTIVATION. ACTIVATION CAN DO ONLY RESSELER.
Please CONTAKT to your RESSELER FOR ACTIVATION BOX.
How install, activate, downloas software. Manual rev.14.08.2018
Download setup,drivers:
1. Download z3x-box setup (drivers, shell): http://cp.z3x-team.com/static/latest_shell.exe
2. Run z3x-shell.exe.
Setup box and card drivers:
4. Connect Z3X-Box to PC
5. Install Z3X-box Drivers from folder x:\Program Files\z3x\Box drivers\
6. Install Z3X-box Drivers from folder x:\Program Files\z3x\Card drivers\
Activation and registration:
7. Run Z3X-Shell
8. Click "Card" in Z3X_Shell. Wizard will start.
9. Will make all steps from wizard.
Download necessary main software:
10. Click "Goto Support" button from Shell and download necessary software.
11. Install downloaded exe.
Start:
12. Choice phone model from list and click "Start"
Support Forums:
https://forum.gsmhosting.com/vbb/f453/
Problem with cards:
If you try start Samsung Tool PRO you got message "Card damaged"
this problem can be solved by update card firmware, how to force card firmware update you can check in this link - Solution.
If you have problem - SMARTCARD not detected/Program Damaged while running software.
1. Try clean SMARTCARD pins. Try use other reader for SMARTCARD. Try reinstall drivers. Try use other PC.
2. Disconnect all other boxes, dongles and try use function repair dead card:
- If function not allowed, remove smart card before goto window with repair dead card function
- then after сhoice repair, immediately put card back and do repair.
3. If BOX under warranty - ask reseller for replace.
4. If BOX not under warranty, and last time box using was not more than 6month, and you have damaged card in hands - buy empty card and we will replace activation to new card.( old card must be in good condition, if your card have damaged or soldering place - replace not possible. in 90% case old card must be shipped to reseller for replace.)
Just send email with SN old and new card: sales @z3x-team.com
Z3x-team(c) 2005-2018
The Following 600 Users Say Thank You to blang For This Useful Post:
Old 02-20-2008, 17:29   #2 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
Big thanks today get dongle and today they active me support and all buyed activation. Very good contact and fast help !!!! If all product supporter will be that will be great. Software work great and if they write that software do software do thus very big thanks for your help and best support then ever. bye
The Following 18 Users Say Thank You to wgmmmx For This Useful Post:
Old 03-28-2008, 07:04   #3 (permalink)
CxVj's Avatar
Member: 122712
Thanks Meter: 121
@z3x-Team
Help, i can't update my firmware dongle card.
Connecting to server... ok
Updating card firmware... [socket error: 10053 or card-uprate-server offline] error
old firmware card v1.2 need to activate into v1.3 my china editor software can't open
thanks in advance
The Following 10 Users Say Thank You to CxVj For This Useful Post:
Old 03-28-2008, 09:34   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
1. Firmware card 1.3 need only for LG 3G software, so you can check "skip firmware update" in updater.exe.
2. Time of server is: 10:00-17:00 gmt+2, try in server time.
3. Try use server n2.
4. Check internet connection.
The Following 11 Users Say Thank You to blang For This Useful Post:
Old 03-28-2008, 10:13   #5 (permalink)
CxVj's Avatar
Member: 122712
Thanks Meter: 121
thanks my problem solved now, china editor activated.
reason: i have 2 internet connections, 1 connections down, second connections good.
Old 06-03-2008, 17:36   #6 (permalink)
Member: 178365
Thanks Meter: 22
i need to activate my dongle. i receive it 2 days ago, but till now, i can't activate it. i already use updater 1.5. can someone help me ??
The Following 4 Users Say Thank You to brutal_array For This Useful Post:
Old 06-04-2008, 06:48   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
your buy from who sir ???
only resseler can help it.
txs
The Following 2 Users Say Thank You to Andra For This Useful Post:
Old 06-04-2008, 13:57   #8 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
About activation ask you resseler.
Who is resseller for you card?
The Following User Says Thank You to blang For This Useful Post:
Old 06-04-2008, 18:30   #9 (permalink)
Member: 178365
Thanks Meter: 22
i already contact my reseller. and they said, they already activate it. but when i tried to update (with 1.5 updater), always show error.
Updating card via Server #2... fail (service offline)
Server1 : banned or unknown card
Server3 : banned or unknown card
Assigning card to user... fail (Unknown card, contact your reseller! But login/pass is ok!)
it's already 3 days since i got this dongle.
what should i do now ???????????????????
Old 06-04-2008, 18:39   #10 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
This mean you resseler not make activation yet.
Ask resseler again.
Please send me pm with card number + resseler name i try solve you problem.
Old 07-19-2008, 10:47   #11 (permalink)
Member: 493553
Thanks Meter: 24
Problem installing UnicodeFont.exe, this screen shot :
Help please step by step installing it........
thank's.
The Following 3 Users Say Thank You to 081372002070 For This Useful Post:
Old 08-02-2008, 03:24   #12 (permalink)
LIKI's Avatar
Member: 1641
Thanks Meter: 54
The Following 3 Users Say Thank You to LIKI For This Useful Post:
Old 08-02-2008, 09:51   #13 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Try now....If not work write me pm
The Following 3 Users Say Thank You to blang For This Useful Post:
Old 08-02-2008, 18:17   #14 (permalink)
Member: 42408
Thanks Meter: 6
sir...how about this?
reved!
Collect info (software versions, card activations, server allows)... ok
Updating card via Server #1... fail (service offline)
Updating card via Server #3... fail (service offline)
thanks
The Following 4 Users Say Thank You to tririval For This Useful Post:
Old 08-03-2008, 10:01   #15 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
if all severs offlline - Try later.
The Following 5 Users Say Thank You to blang For This Useful Post:
All z3x user read this wichielrico Z3X-Team Products 6 06-15-2011 15:02
Read this before using AERIX !!! sweunlockers Sony Ericsson 3 11-06-2009 08:50
fg box activated pack5 ... free one year access to support needed noure30 FuriousGold 6 08-01-2009 20:45
Voda 716 clip user read this befor use it paklink Vodafone Star 1 09-08-2008 15:56
All Original Prodigy Box User Read this.... MicrostarGSM® Federal One 0 07-08-2004 06:07
Page generated in 0.36403 seconds with 10 queries
