Old 01-29-2010, 21:25   #1 (permalink)
Member: 1153599
Question Unlock/Unlocking Samsung S8300 with Z3X Box - Need Help!
I have a Samsung Tocco Ultra S8300. I want to unlock it by using the Z3X Box with the latest, Samsung Qualcomm Tool 6.4.05 software.
Can anyone please help me on the following:
I want to know which cable I need to use, it says mini USB. Does that mean I can use the normal phone USB cable for this phone? or is there some other special cable, if so where can I get it from and does it have some code name.
Also can you please kindly show me the full Instructions/Steps that are required to unlock this phone by using the Z3X Box.
Any help from someone would be greatly appreciated. Many Thanks.
Old 01-29-2010, 21:54   #2 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,141
you need micro usb , that come whith phone conect to phone and install all drivers , than make read codes
Old 01-30-2010, 05:30   #3 (permalink)
Member: 54646
mini USB is cable changer of Samsung or Nokia .
Old 07-12-2010, 17:25   #4 (permalink)
Member: 290273
Thanks Meter: 9
with phone on?
with or without sim?
no need to flash??
regards
stemo
Old 07-13-2010, 02:59   #5 (permalink)
Member: 856803
Sonork: 100.1592550
Thanks Meter: 151
Arrow
At first u need micro usb cable(Micro usb mean its length is only shorter)
then press 9+power key on ur mobile
Now ur mobile go to download mode
Now u connect Micro usb cable on ur pc or connect it on software box usb socket
now ur pc has recogonised ur mobile
then its need to install driver
after install it shows Your new hardware is ready for use
Now go to samsung 3g tool then click just "unlock"
gud luck,happy unlocking......
The Following 2 Users Say Thank You to ..::MOBILES::.. For This Useful Post:
Old 07-14-2010, 09:43   #6 (permalink)
Member: 290273
Thanks Meter: 9
you cant be serious that micro means shorter. lol.
micro and mini usb are different in size
micro usb is i.e ca101
mini usb is i.e dke2
anyway you unlock this model in download mode
correct???
as thats what you have put???
stemo
Old 07-23-2010, 15:38   #7 (permalink)
champions1's Avatar
Member: 1157490
Sonork: 100.1638346
Thanks Meter: 74
you can unlock it other way as well.
1.Reset phone with*2767*3855#
2.put in qualcom mode *#782872#
3.put usb(no matter mini or normal size) in Z3X box com port,it'll search & install drivers automatically.
4.select com portcom 202zte diagnosticinterface 6000....)
5.press unlock sp
6.wait untill procedure finished.
7.put original sim in phone and power it on.
8.put netlock code,#7465625*638*........
unlock done 100% tested.
enjoy
The Following 5 Users Say Thank You to champions1 For This Useful Post:
Old 08-26-2010, 18:32   #8 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 190
Sending Loader... OK
Start Loader... Error Write to support for check
???? can't unlock phone ?
Old 08-26-2010, 18:36   #9 (permalink)
Member: 190492
Thanks Meter: 190
ok now it ok but should tape this , type *#7465625# and do sp unlock see this :
Reading security... error! (Insert SIM or type *#7465625#)
Searching Qualcomm USB interface... detected (COM13)
Model: S8300
IMEI: 35627603157336
SW: S8300BOIH3
Reading data from phone... OK
Reading security... OK
Calculating codes... OK (time - 00:00:09)
Freeze code... 02525290
NET lock code... 00000000
Sub lock code... 00000000
SP lock code... 00000000
CP lock code... 00000000
SIM lock code... 12369874
Activa code... 12369874
How to enter codes:
NET: #7465625*638*00000000#
Sub: #7465625*782*00000000#
SP: #7465625*77*00000000#
CP: #7465625*27*00000000#
SIM: #7465625*746*12369874#
Old 10-25-2010, 06:00   #10 (permalink)
SanjanMobile's Avatar
Member: 316292
Thanks Meter: 102
5.press unlock sp
enjoy
perfect solution thanks
Old 12-21-2011, 14:18   #11 (permalink)
Member: 1154494
Thanks Meter: 3
Thumbs up Unlocked successfully Samsung S8300v
5.press unlock sp
enjoy
How i done with the help of champions1 & Z3X
2.put in Samsung mode *#726872#
4.select com port - normally it will automatically select the z3x box
5.Unlock sp method - Direct
6.press unlock sp
7.wait until procedure finished.
8. switch on phone check lock status: *#7465625# NET lock should be OFF
Picture help Cell Care Mobiles
Old 03-21-2012, 14:49   #12 (permalink)
Member: 1242652
Sonork: mdobrais
Thanks Meter: 9
Searching USB Device... detected (COM8)
Reading Phone Info... OK
Model: GT-S8300
Factory SW: S8300BVIC1
CountryCode: ORA
UniqueNumber: 70120000451873
MemoryPhone: K5R2G1GACC(S8300)S
SW: S8300XEIC4
IMEI: xxxxxxxxxxxxxxx
Reading SysInfo... OK
Searching server... error (Maybe OLD Security)
Change Mode to Qualcomm and Try Again
Done with Samsung 3G tool ver 9.4
where is the problem? but in Qualcomm its not find Qualcomm mode
Old 07-11-2012, 09:12   #13 (permalink)
surajnad's Avatar
Member: 454011
Sonork: 1656095
Thanks Meter: 147
Model: GT-S8300
CountryCode: ORA
SW: S8300XEIC4
I have same error help me z3x team argent
Old 08-08-2013, 08:14   #14 (permalink)
Member: 1527882
Thanks Meter: 3
Selected model: S5292
Selected port: COM3 Z3X Serial Port
Selected port speed: 921600
Waiting phone... OK
Sending preloader... OK
Sending loader... OK
Checking Flash ID... OK
Detected Flash ID: 11F000FF
Rebooting phone... OK
Now connect phone to UART cable
Checking phone at COM3... timeout
Done with Samsung Tool v.15.1
Old 11-13-2013, 13:58   #15 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
select new security if unlock stop after connecting
thanks to you all by gsmzaman
Samsung s8300 successfully unlock with z3x box top man Z3X-Team Products 0 03-21-2010 16:53
z3x box need help shawgsm Z3X-Team Products 6 12-23-2009 11:55
How to unlock Samsung S8300 with Z3X-team hoangtruongson Z3X-Team Products 2 05-27-2009 07:25
Unlock your softbank phone with z3x-box! blang Main Sales Section 0 03-24-2009 19:34
problem with my box! need help .:ramtelecom:. MT-BOX 6 07-13-2007 14:42
Page generated in 0.26133 seconds with 9 queries
