05-24-2016, 14:12 | #16 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 956406 Status: Offline Thanks Meter: 55 | J700H/DS frp Quote:
<OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/018> Odin engine v(ID:3.1100).. <ID:0/018> File analysis.. <ID:0/018> SetupConnection.. <ID:0/018> Initialzation.. <ID:0/018> Get PIT for mapping.. <ID:0/018> Firmware update start.. <ID:0/018> SingleDownload. <ID:0/018> sboot.bin <ID:0/018> NAND Write Start!! <ID:0/018> cm.bin <ID:0/018> FAIL! <ID:0/018> <ID:0/018> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) When try flash give ME error sboot...how can I flash ? Or how can I unlock FRP on this phone ? | |
The Following User Says Thank You to ADIVASRO For This Useful Post: |
05-25-2016, 09:44 | #17 (permalink) | |
Member: 956406 Status: Offline Thanks Meter: 55 | FRP lock Quote:
05-28-2016, 03:48 | #18 (permalink) |
Insane Poster Join Date: Feb 2016 Location: panama city
Member: 2536862 Status: Offline Thanks Meter: 4 | team lower the flash of this cell and kill him not turn anything I do as going to postiar one flas that kills the cell and now not enter anything in no way douloder sudden death FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on phone in download mode (turn off phone, press vol.down + home + power). 6. Connect phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: SM-J700H/DS Software version: 25.5 File analysis... OK Total file size: 0x77F50530 (1919 Mb) Searching USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:01:21) Done with Samsung Tool PRO v.25.5 |
05-28-2016, 06:07 | #19 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,057 | Quote:
Br, xerraco | |
08-03-2016, 14:30 | #24 (permalink) |
Freak Poster Join Date: Jul 2011 Location: in /dev/null/01110cod3r1100101
Member: 1613754 Status: Offline Sonork: 1623976 Thanks Meter: 115 | Samsung J700H FRP 6.0.1 error Samsung J700H/DS 6.0.1 frp remove error Samsung Tool Pro 26.2 Searching Samsung USB Flash Interface... detected COM19 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error After turn on same FRP ON Done with Samsung Tool PRO v.26.2 |
09-14-2016, 07:44 | #25 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2615403 Status: Offline Thanks Meter: 0 | Samsung Tool Pro 26.6 Searching Samsung USB Flash Interface... detected COM19 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing EE lock... error Plz guide me whts worng help me |
09-14-2016, 10:38 | #26 (permalink) |
Insane Poster Join Date: Nov 2013
Member: 2064922 Status: Offline Thanks Meter: 6 | Downgrade the phone to 5.1.1 and use this method 1: download sidesync. Exe 2: connect your phone with WiFi. 3: connect the phone to your system it will show you an option to open with browser and choose the browser. 4: download quick shortcut maker,after u download it ,from your browser select bookmark and select download history you will see your downloaded file install it. 5: from the app u just install search for Google manager ,and click on it , You will see "email and password" click on it , you will see an option saying "try it" click on it, by your right hand side at the top there are 3 dots, click on them and click on browser signing, put your email and password. 6: after that go back to the main activation screen and you are good to go. Sent from my SM-N920C using Tapatalk |
The Following User Says Thank You to hack99209 For This Useful Post: |
09-14-2016, 15:36 | #27 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
09-14-2016, 15:41 | #28 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Try with this post Sir, tested 100% http://forum.gsmhosting.com/vbb/f777...ested-2133391/ |
10-11-2018, 15:40 | #30 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | j3 frp how? [Answered] hi i got samsung sm-j320fn , its locked with google FRP . how to activate ADB without having access to menu ? ADB must be activated in any way (you can flash sBoot from combination firmware Done with Samsung Tool PRO v.33.8 LMY47V.J320FNXXU0ARA1 |
