Old 05-24-2016, 14:12   #16 (permalink)
Member: 956406
Thanks Meter: 55
J700H/DS frp
Originally Posted by ..::KASHIF::.. View Post
after write this
(J700HXXU1AOK5_J700HOJV1AOK6)
Downlod By support
and try again problem is solve
Operation: Reset FRP/React/EE
Selected model: SM-J700H
Software version: 24.2
Searching Samsung USB Flash Interface... detected COM5
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Done with Samsung Tool PRO v.24.2
<ID:0/018> Added!!
<OSM> Enter CS for MD5..
<OSM> Binary Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/018> Odin engine v(ID:3.1100)..
<ID:0/018> File analysis..
<ID:0/018> SetupConnection..
<ID:0/018> Initialzation..
<ID:0/018> Get PIT for mapping..
<ID:0/018> Firmware update start..
<ID:0/018> SingleDownload.
<ID:0/018> sboot.bin
<ID:0/018> NAND Write Start!!
<ID:0/018> cm.bin
<ID:0/018> FAIL!
<ID:0/018>
<ID:0/018> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
When try flash give ME error sboot...how can I flash ? Or how can I unlock FRP on this phone ?
The Following User Says Thank You to ADIVASRO For This Useful Post:
Old 05-25-2016, 09:44   #17 (permalink)
Member: 956406
Thanks Meter: 55
FRP lock
Originally Posted by ADIVASRO View Post
<ID:0/018> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/018> cm.bin
<ID:0/018> FAIL!
<ID:0/018>
This is a REAL solution... https://www.youtube.com/watch?v=IJZ74XwarxI
Old 05-28-2016, 03:48   #18 (permalink)
Member: 2536862
Thanks Meter: 4
team lower the flash of this cell and kill him not turn anything I do as going to postiar one flas that kills the cell and now not enter anything in no way douloder sudden death
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. If you have one file firmware, then you must check 'Use one package file' option.
4. Check flashing options if needed (Repartition, EFS clear, Boot update).
5. Power on phone in download mode (turn off phone, press vol.down + home + power).
6. Connect phone to PC with USB cable, install drivers if needed.
7. Press 'Flash' button.
Operation: Flash
Selected model: SM-J700H/DS
Software version: 25.5
File analysis... OK
Total file size: 0x77F50530 (1919 Mb)
Searching USB Flash Interface... detected COM32
Sending sboot.bin... OK
Sending cm.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending modem.bin... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:01:21)
Done with Samsung Tool PRO v.25.5
Old 05-28-2016, 06:07   #19 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,057
FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
Needs JTAG to revive phone.
Br,
xerraco
Old 05-28-2016, 14:46   #20 (permalink)
Member: 2536862
Thanks Meter: 4
remove the flash team that kills the cell of bleng support passing this j700h dead after flash
Old 05-28-2016, 14:56   #21 (permalink)
Member: 1631844
Thanks Meter: 32
Use z3x tools pro 25.5
Old 06-04-2016, 18:54   #22 (permalink)
Member: 2281909
Yes this is real U solved My problem thanks
Old 06-17-2016, 13:41   #23 (permalink)
Member: 808967
Thanks Meter: 155
I help with flash support j700h Z3X I kill as urgent aid to revive him
Old 08-03-2016, 14:30   #24 (permalink)
cod3r's Avatar
Member: 1613754
Sonork: 1623976
Thanks Meter: 115
Samsung J700H FRP 6.0.1 error
Samsung J700H/DS 6.0.1 frp remove error
Samsung Tool Pro 26.2
Searching Samsung USB Flash Interface... detected COM19
Erasing FRP... OK
Erasing EE lock... error
After turn on same FRP ON
Done with Samsung Tool PRO v.26.2
Old 09-14-2016, 07:44   #25 (permalink)
Member: 2615403
Samsung Tool Pro 26.6
Plz guide me whts worng help me
Old 09-14-2016, 10:38   #26 (permalink)
Member: 2064922
Thanks Meter: 6
Downgrade the phone to 5.1.1 and use this method
1: download sidesync. Exe
2: connect your phone with WiFi.
3: connect the phone to your system it will show you an option to open with browser and choose the browser.
4: download quick shortcut maker,after u download it ,from your browser select bookmark and select download history you will see your downloaded file install it.
5: from the app u just install search for Google manager ,and click on it ,
You will see "email and password" click on it , you will see an option saying "try it" click on it, by your right hand side at the top there are 3 dots, click on them and click on browser signing, put your email and password.
6: after that go back to the main activation screen and you are good to go.
Sent from my SM-N920C using Tapatalk
The Following User Says Thank You to hack99209 For This Useful Post:
Old 09-14-2016, 15:36   #27 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Hi, Br, i try to downgrade, but fail
Old 09-14-2016, 15:41   #28 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Try with this post Sir, tested 100%
http://forum.gsmhosting.com/vbb/f777...ested-2133391/
Old 10-05-2016, 08:19   #29 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
http://forum.gsmhosting.com/vbb/f453...ethod-2140841/
Old 10-11-2018, 15:40   #30 (permalink)
Member: 7844
Thanks Meter: 182
j3 frp how? [Answered]
hi
i got samsung sm-j320fn , its locked with google FRP . how to activate ADB without having access to menu ?
ADB must be activated in any way (you can flash sBoot from combination firmware
Done with Samsung Tool PRO v.33.8
LMY47V.J320FNXXU0ARA1
Page generated in 0.25878 seconds with 8 queries
