09-02-2016, 05:24 | #1 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | FRP Remove for all samsung devices 2016, with latest security patch. Now the magic itself is in samsung modem with some old AT Commands we can do the trick. Ok Lets get started: 1) With the phone in language screen we just need to put a sim card and enable wifi connection so now we need a terminal who connect to samsung modem and send the at commands to the modem. These steps will be crucial for the operation!!!. When sim card was put in the phone and wifi connection enabled and connected we can proceed to next step 2) Next step is download a terminal who connect to samsung modem just download and install Realterm: https://sourceforge.net/projects/realterm/files/ After install connect your samsung device to pc using usb connection, and open device manager under modems, right click and click properties Under modem check com port: COM14 After check the com port number, open realterm and connect to com port RealTerm port number must be according to the above number, change if not. now open the com port in realterm. Now go to display tab in realterm and check half duplex after checking half duplex go to send tab, at this point we will do the magic and send the at commands to samsung modem. Type “at+creg?\r\n” and click "Send ASCII" (Without Quotes) this command is for enable network registration. when at command for network registration was successful, we need to send another command to make a phone call. Type “atd1234;\r\n” And click “Send ASCII” button. this command is for dial a phone call to the number 1234 or whatever number we put on it. After command was sent, wait a few second and the phone will make a phone call, when the phone call start immediately end the call and quickly select create contact 3) In create contact menu, slide down and find the option SCAN BUSSINESS CARD and and click agree in galaxy apps tos. ****PD: for the devices that don't have the option of bussiness card just don't select create contact, need to select Message Option!!**** at the end of this thread you will see how to do it!! when click agree on galaxy apps tos, login to your samsung account or create a new samsung account and login, click in search and input Es File Explorer, and download install and open the app. after that the most important step is the installation of bypass apk, for some devices with microsd card support just put the Frp Bypass.Apk into the root of sd card and install it with es file explorer like in the picture!!! Frp Bypass apk download: Easy Frp Bypass - Download - 4shared - Jesus Britto **** for devices WHO DONT HAVE micro sd support like Samsung Galaxy S6, Edge and Edge+ need to use es file explorer's bluetooth feature to enable bluetooth in the device to receive the apk of bypass from another device!!**** 4) After install open the Bypass Apk and click Google Account Login!! In the next screen click browser sign in! to sign in with your Google Account, input your gmail and password when login success will return to the previous screen!!! and after that click on bypass go to settings 1, in settings menu go to accounts and check if your google account was signed in the device succesfully, now return to the previous page and RESTART THE PHONE!! 5) When phone restarts just follow the steps normally and the google account will be added with your google account and will bypass frp lock and enter to Main menu of Touchwiz UI!!! For Remove the frp lock permanently!! just in setting options delete your google account and samsung account that you use to bypass frp lock, and Navigate to Backup & reset and factory reset data!! after this you will remove the frp lock permanently!!! to check frp lock was removed enter in download mode and check is FRP LOCK IS OFF. ****In the Third Step: For the devices that don't have the bussiness card option in contact create menu need to Click Message and a message menu will be open with the number that we call, just type in message https://www.google.com and open the link that will open the samsung browser and find in google es file explorer apk and install it, or type this url: Zippyshare.com - com.estrongs.android.pop-4.1.3-APK4Fun.com.apk that link is for download es file explorer apk, when download complete install it from samsung browser just find the download history and install it from it and follow the next step 4!!**** I Hope this help people who ask for frp remove solution, remember to read all steps carefully and follow the instructions!! This method was tested in many devices like Galaxy S6 variants, J Series, A Series all new samsung phones. Best Regards Jesus Britto from VENEZUELA. |
The Following 40 Users Say Thank You to jesusbritto1 For This Useful Post: |
09-02-2016, 06:15 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Holy smokes did anyone try this? If it works hats off to jesusbritto1 for the most detailed and helpful instructions ever. |
The Following User Says Thank You to cafonabob1 For This Useful Post: |
09-02-2016, 06:41 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | I think it found by rootjuncky and its working without any problem |
The Following User Says Thank You to Ransiri For This Useful Post: |
09-02-2016, 07:05 | #5 (permalink) |
Member: 2262368 Status: Offline Thanks Meter: 57 | later i will upload a video tutorial, with some devices on hands, with the Business card method (Galaxy APPS) and browser method for devices who don't have the business card option. this was tested on many devices. |
The Following User Says Thank You to jesusbritto1 For This Useful Post: |
09-02-2016, 07:15 | #6 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Kathmandu Age: 33
Member: 1721729 Status: Offline Sonork: 100.1623685 Thanks Meter: 28 | The Actual solution is on this link. Credits : RootJunky If anyone need video tutorial its here on this link. If you post a solution please mention and give credits to the real developers. Give respect and take respect. BR, Last edited by md.kishor23; 09-02-2016 at 07:16. Reason: Link Updated |
The Following User Says Thank You to md.kishor23 For This Useful Post: |
09-02-2016, 08:16 | #7 (permalink) |
Freak Poster Join Date: Jul 2007 Location: pakistan
Member: 557894 Status: Offline Sonork: no Thanks Meter: 35 | copy of sam video..pls chak.https://www.youtube.com/watch?v=7AQTUS7d48M |
09-02-2016, 11:53 | #8 (permalink) |
Member: 2262368 Status: Offline Thanks Meter: 57 | I not copy rootjunky solution see the video and see the guide, frp apks are not the same!! browser method is not the same, only business card method! the frp bypass apk that i used is from Easy-firmware.com and i not disrespecting nobody! and give credit to the real developers??, is not a develop!! is only at commands that are send to the samsung modem to make a call where's the developer?? please.. i only try to help, my friend. Last edited by jesusbritto1; 09-02-2016 at 11:59. |
09-02-2016, 12:32 | #9 (permalink) |
Member: 1721729 Status: Offline Sonork: 100.1623685 Thanks Meter: 28 | Developing commands are not easy, programmers know that. So I think you should give credits using links to everyone which method you used. BR, |
09-02-2016, 12:44 | #10 (permalink) |
Member: 557894 Status: Offline Sonork: no Thanks Meter: 35 | I think you should give credits using links to everyone which method you used. |
The Following User Says Thank You to muzaffar shah g For This Useful Post: |
09-02-2016, 13:02 | #11 (permalink) |
Member: 2262368 Status: Offline Thanks Meter: 57 | lol developing commands?? the at commands are OLD and was used for do a lot of things! y suggest you to read the GSM/GPRS, MODEMS AT Commands reference guide.https://www.sparkfun.com/datasheets/...e_Guide_r0.pdf Credits to Easy-Firmware! for the frp apk http://easy-firmware.com/ real term developers for real term: Terminal Software are u happy now? Last edited by jesusbritto1; 09-02-2016 at 13:05. Reason: Link Updating |
09-06-2016, 19:50 | #14 (permalink) | |
Junior Member Join Date: Mar 2015
Member: 2358647 Status: Offline Thanks Meter: 4 | Quote:
old or new commands , its a solution in which somebody first came to the idea to do that and its obvious you were not that one ? ok ? metal is well known but ferrari is special becuase of using parts in unique way Give respect , Get respect | |
The Following 2 Users Say Thank You to darya-m0bi For This Useful Post: |
