Old 12-19-2015, 09:52   #1 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
samsung note 4 n910 cert write problem
please give me solution
Old 12-19-2015, 10:02   #2 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
after write nv data security demage OK but no problem is
Checking certificate file... OK
KEY ID: 0065
Waiting ADB device... OK
Reading phone info...
Model: SM-N910C
Android version: 5.0.1
Product code:
Phone version:
PDA version: N910CXXU1BOC5
CSC version: N910COJV1BOC2
CSC country code: Egypt
CSC sales code: EGY
HW version:
Phone S/N:
Modem board:
RF cal date:
IMEI:
Checking Super user right... true
Reading nv data... OK
Analisis NV data... OK
Writing nv data... OK
Rebooting phone... OK
Model: SM-N910C
Product code:
Phone version:
CSC sales code: EGY
HW version:
Phone S/N:
Modem board:
RF cal date:
IMEI:
Initialization AT RIL... error
Done with Samsung Tool PRO v.23.7
Old 12-19-2015, 10:05   #3 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 767
z3x have problem in this model.
i have same problem too.
[ 18/12/2015 18:33:00 ] Operation: Write CERT
[ 18/12/2015 18:33:00 ] Selected model: SM-N910C
[ 18/12/2015 18:33:00 ] Software version: 23.7
[ 18/12/2015 18:33:00 ] Checking certificate file... OK
[ 18/12/2015 18:33:00 ] KEY ID: 0065
[ 18/12/2015 18:33:00 ] Waiting ADB device... OK
[ 18/12/2015 18:33:00 ] Reading phone info...
[ 18/12/2015 18:33:00 ] Model: SM-N910C
[ 18/12/2015 18:33:00 ] Android version: 5.1.1
[ 18/12/2015 18:33:00 ] Product code:
[ 18/12/2015 18:33:00 ] Phone version: N910CXXU1COJ5
[ 18/12/2015 18:33:00 ] PDA version: N910CXXU2COJ5
[ 18/12/2015 18:33:00 ] CSC version: N910COLB2COJ5
[ 18/12/2015 18:33:00 ] CSC country code: THAILAND
[ 18/12/2015 18:33:00 ] CSC sales code: THL
[ 18/12/2015 18:33:00 ] HW version:
[ 18/12/2015 18:33:00 ] Phone S/N:
[ 18/12/2015 18:33:00 ] Modem board: DB7450R
[ 18/12/2015 18:33:00 ] RF cal date: 1234.56.78
[ 18/12/2015 18:33:00 ] IMEI:
[ 18/12/2015 18:33:00 ] Checking Super user right... true
[ 18/12/2015 18:33:00 ] Reading nv data... OK
[ 18/12/2015 18:33:00 ] Analisis NV data... error
[ 18/12/2015 18:33:00 ] Security damaged
[ 18/12/2015 18:33:00 ] Operation: Write NV DATA
[ 18/12/2015 18:33:00 ] Writing nv data... OK
[ 18/12/2015 18:33:00 ] Recalculating md5... OK
[ 18/12/2015 18:33:00 ] Deleting backup... OK
[ 18/12/2015 18:33:00 ] Rebooting phone... OK
[ 18/12/2015 18:33:00 ] Write NV Data done
[ 18/12/2015 18:34:00 ] Operation: Write CERT
[ 18/12/2015 18:34:00 ] Selected model: SM-N910C
[ 18/12/2015 18:34:00 ] Software version: 23.7
[ 18/12/2015 18:34:00 ] Checking certificate file... OK
[ 18/12/2015 18:34:00 ] KEY ID: 0065
[ 18/12/2015 18:34:00 ] Waiting ADB device... OK
[ 18/12/2015 18:34:00 ] Reading phone info...
[ 18/12/2015 18:34:00 ] Model: SM-N910C
[ 18/12/2015 18:34:00 ] Android version: 5.1.1
[ 18/12/2015 18:34:00 ] Product code:
[ 18/12/2015 18:34:00 ] Phone version: N910CXXU1COJ5
[ 18/12/2015 18:34:00 ] PDA version: N910CXXU2COJ5
[ 18/12/2015 18:34:00 ] CSC version: N910COLB2COJ5
[ 18/12/2015 18:34:00 ] CSC country code: THAILAND
[ 18/12/2015 18:34:00 ] CSC sales code: THL
[ 18/12/2015 18:34:00 ] HW version:
[ 18/12/2015 18:34:00 ] Phone S/N:
[ 18/12/2015 18:34:00 ] Modem board: DB7450R
[ 18/12/2015 18:34:00 ] RF cal date: 1234.56.78
[ 18/12/2015 18:34:00 ] IMEI:
[ 18/12/2015 18:34:00 ] Checking Super user right... true
[ 18/12/2015 18:34:00 ] Reading nv data... OK
[ 18/12/2015 18:34:00 ] Analisis NV data... error
[ 18/12/2015 18:34:00 ] Security damaged
The Following User Says Thank You to nongmobile For This Useful Post:
Old 12-19-2015, 10:14   #4 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
yes you are right bro same problem here
we need solution if possible
Old 12-19-2015, 12:54   #5 (permalink)
vickyjadhav6161's Avatar
Member: 2386560
Sonork: NOW I DON'T USE IT
Thanks Meter: 561
here is u r 100% tested solution please restore your efs from back folder [C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\EFS]
then reset efs then write cert..................and post result here ........
if my post useful dont forget press thanks
Old 12-20-2015, 08:02   #6 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
after restore efs file still same problem
again security demage
Old 12-20-2015, 08:10   #7 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
after write nv data security ok but when i write cert file show error
check log
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore.
7. Press 'Write NV DATA' if you need to restore NV backup.
KEY ID: 0065
Model: SM-N910C
Product code:
Phone version:
CSC sales code: EGY
HW version:
Phone S/N: RF8FB1TQF5D
Modem board:
RF cal date:
IMEI:
Model: SM-N910C
Product code:
Phone version:
CSC sales code: EGY
HW version:
Modem board:
RF cal date:
IMEI:
Old 12-20-2015, 08:23   #8 (permalink)
Member: 2386560
Thanks Meter: 561
please restore efs from backup folder z3x
Old 12-20-2015, 08:25   #9 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
I restore it already. After restore efs again security demage
Old 12-20-2015, 08:28   #10 (permalink)
Member: 2386560
Thanks Meter: 561
i'll give u tested efs wait
Old 12-20-2015, 08:35   #11 (permalink)
Member: 2386560
Thanks Meter: 561
tested efs http://www.4shared.com/file/3-DAj3ezba/EFS_SM-N910C_N910CXXU1ANK5_355.html
do with z3x
Old 12-20-2015, 08:54   #12 (permalink)
Member: 2386560
Thanks Meter: 561
post result.................
Old 12-22-2015, 08:35   #13 (permalink)
Member: 2386560
Thanks Meter: 561
bro try with my efs...............
Old 12-28-2015, 08:44   #14 (permalink)
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
after write EFS file again same problem
EFS WRITE
CERT FILE WRITE
Old 05-17-2016, 07:32   #15 (permalink)
Crazy Poster
Member: 2076822
Thanks Meter: 2
Originally Posted by vickyjadhav6161 View Post
bro plizz help need N910H efs file tested
Page generated in 0.24155 seconds with 8 queries
