G313HU Restart problem After Selecting wrong model G313HU Restart problem After Selecting wrong model I selected model G313H |
i was trying to repair imei OF G313HU By model selecting G313h I dint saw the update i tried In samsaung tool 18.3 |
http://forum.gsmhosting.com/vbb/f453...rters-1139639/ so hard read this?? 3. Thread BODY should contain full description of problem: --- important information wanted from user for get any simple answer --- - phone models, - status of phone before any job with phone, - phone firmware, - backups *.tar better 1st one, - all logs of each job with phone, - logs of job of last actual version of z3x sw for such models. ---- without such information in 90% case your post will be without any answer --- |
here is the repair logs -------------------------- 8-2-2015_14-45-33 -------------------------- Selected model: SM-G313H Selected port: COM1 Communications Port Selected port speed: 115200 Waiting ADB device... Operation aborted Done with Samsung Tool v.18.3 Selected model: SM-G313H Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... Operation aborted Done with Samsung Tool v.18.3 Selected model: SM-G313H Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: SM-G313HU Android version: 4.4.2 Product code: SM-G313HRWHINS Phone version: G313HUDDU0ANG6 PDA version: G313HUXXU0ANGJ CSC version: G313HUODD0ANG4 IMEI: 355370061394118 Phone S/N: RZ1F829KX4Z Checking Super user right... true Detecting NV partitions... not found Loading NV partitions from database... OK Repairing network... error 1 Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool v.18.3 Here is the flashing logs -------------------------- 8-2-2015_17-27-12 -------------------------- Selected model: SM-G313HU Selected port: COM23 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x3BA8E294 Searching USB Flash Interface... detected COM3 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\SM-G313HU_8-2-2015_17-29-21.pit Sending sboot.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending system.img... OK Sending hidden.img... OK Sending BcmBoot.img... OK Sending param.lfs... OK Flashing done (time - 00:02:57) Done with Samsung Tool v.18.8 |
ur problem solved or not Quote:
but canot solved |
write backup using last version of software |
after write backup still problem canot set alive .samsung logo then restart i flash all files still problem wht can now i do help me plz |
Hello and also I have this phone with only logo pb have flash diferents file but results same.Cant repaiar it.Is there anybody that know how can I repaiar this phone. FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G316HU Software version: 23.5 File analysis... OK Total file size: 0x3F9B72A0 (1017 Mb) Searching USB Flash Interface... detected COM21 Setup connection... OK Reading PIT from phone... OK Sending BcmBoot.img... OK Sending sboot.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:25) Done with Samsung Tool PRO v.23.5 |
samsung G313H ace NXT phone restarting problem tryed to flash but error FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G313H Software version: 29.5 File analysis... OK Total file size: 0x3E2B7ACC (994 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending spl.img... error Done with Samsung Tool PRO v.29.5 can any one solve this plz Thanks |
