G388f unlock solution????????? UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 Operation: Unlock Selected model: SM-G388F Software version: 25.4 Waiting ADB device... OK Reading phone info... Model: SM-G388F Android version: 4.4.4 Product code: SM-G388FDSAO2U Phone version: G388FXXU1AOH4 PDA version: G388FXXU1AOH4 CSC version: G388FO2U1AOG1 CSC country code: UK & IRE CSC sales code: O2U HW version: MP 0.500 Phone S/N: R58GC11Z8HR Modem board: RF cal date: 20151217 IMEI: 354201076698220 Checking Super user right... false This model not supported for auto root Done with Samsung Tool PRO v.25.4 |
G388f Plz send me root file??????;););) |
use root file from support use odin to flash this file then unlock ;) |
Br, xerraco |
after root phone hang <ID:0/008> Added!! <ID:0/008> Odin engine v(ID:3.1005).. <ID:0/008> File analysis.. <ID:0/008> SetupConnection.. <ID:0/008> Initialzation..:confused::confused: <ID:0/008> Get PIT for mapping.. <ID:0/008> Firmware update start.. <ID:0/008> SingleDownload. <ID:0/008> system.img <ID:0/008> NAND Write Start!! <ID:0/008> boot.img <ID:0/008> RQT_CLOSE !! <ID:0/008> RES OK !! <ID:0/008> Removed!! <ID:0/008> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
Can we use this method for 5.1.1? downgrade might give problems. |
