04-04-2019, 14:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | What combination software to use? Then I removed FRP with Samsung Tool PRO. In fact Samsung Tool PRO only reported that FRP was removed . So I flashed normal firmware like G935FXXU3ERL3_CL14843133_QB20951136_REV00_user_low _ship_meta.tar and found out that FRP was NOT removed. So I flashed again with the same combination firmware but this time the mobile became bricked( I had to flash a normal firmware again to unbricked it). Where I made a mistake? What Combination software to use now so that I can try again to remove FRP? Thanks for help |
04-04-2019, 14:46 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Install combination COMBINATION_FA60_G935FXXU3ARI2_ Use method memory ufs via cable uart via z3x software, and reset frp once the frp reset installed this firmware G935FXXS3ERHD has been reset in 4 files ap, bl, cp, home_csc do not install the file csc, use file home_csc G935F Multi Firmware with PIT G935FXXS3ERHD https://mega.nz/#!LxJXRSrK!pmIUsbXkR...7mqbJZGBWksTjo Last edited by amleto90; 04-04-2019 at 14:53. | |
04-05-2019, 11:40 | #6 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | It can detect ADB, it reports that FRP was removed, but when I reflashed with a normal firmware, FRP was still there. Should I try again or it is not possible to use that ADB method for that kind of mobile? |
04-05-2019, 12:06 | #7 (permalink) | |
once you reset frp and flash the firmware how do you do it in 4 files using the home_csc file or with the entire firmware not in 4 files or using csc instead of home_csc? | |
04-05-2019, 15:14 | #8 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | @amleto90: I do not have UART cable at the moment.So, I tried with ADB but it does not work. I used ap, bl, cp, home_csc but no success, probably because FRP was not removed by ADB method - only reported . So I will have to try with UART cable later |
04-05-2019, 15:56 | #9 (permalink) | |
Method hushsms https://m.youtube.com/watch?v=UV7r-kMrHog Or this method https://m.youtube.com/watch?v=k73dQOXPAJU | |
