12-28-2008, 00:09 | #3 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,636 | [quote=bronce;4003835]and team, can not FLASH.......................kindly fix................. Flashing will be fixed in next qualcomm version. Abount unlocking. = Use 2in1 cable. After cable connected try read NVM. If reading error - this mean COM part of cables is not connected. Check com part and try again read nvm till ok. after make unlock |
The Following User Says Thank You to blang For This Useful Post: |
12-28-2008, 12:20 | #6 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,636 | Quote:
Old phones can be unlocked via samsung mode with 2in1 cable. In you screen №2 i see read NVM - error ( this is mean phone not connected via COM part of 2in1cable.) and this is not software problem. You must check connector, try clean connector. You have 100% problem in com part 2in1 cabel. Play with cable till NVM reading was succes. Only Nvm reading mean - cable 2in1 connected good. And only after this you can unlock phone. | |
