05-31-2020, 12:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: here
Member: 420598 Status: Offline Thanks Meter: 135 | g892u tmp cannt unlock Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G892U Selected port: COM337 SAMSUNG Mobile USB Serial Port Software version: 40.1 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 6 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G892U Android version: 9 PDA version: G892USQS6CTB2 CSC version: G892UOYN6CTB2 Phone version: G892USQS6CTB2 Product code: SM-G892UZAATMB CSC country code: USA CSC sales code: TMB Phone SN: R38K406RWKK IMEI: 352157091240236 HW version: REV0.4 RF cal date: 2018.04.10 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: ABSENT Searching Samsung diag port... detected COM337 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM162 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Server error: Hash not found Done with Samsung Tool PRO v.40.1 |
