10-03-2021, 09:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: manchester, united kingdom Age: 39
Member: 288521 Status: Offline Thanks Meter: 685 | g920f drk fix error bit6 please help [Answered] phone was on but had no baseband.. i full flashed bit6 firmware.. and now drk error cant repair drk please help REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G920F Software version: 43.16 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM12 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G920FXXS6ETI6 Platform: exynos7420 Boot serial: 0715f7b01da92c3a Product board: zeroflte Initialization zTool... OK Running zTool, please wait... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.43.16 |
