11-03-2015, 07:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | G925F flash error FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925F Software version: 23.2 File analysis... OK Total file size: 0xE2232A70 (3618 Mb) Searching USB Flash Interface... detected COM16 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... error timeout Done with Samsung Tool PRO v.23.2 have try without pit may be its pb. THANKS Last edited by TUN10; 11-03-2015 at 07:09. |
11-03-2015, 12:17 | #2 (permalink) |
No Life Poster Join Date: May 2012 Location: Firmwares
Member: 1761687 Status: Offline Sonork: 100.1669047 Thanks Meter: 494 | Bro download these files first: CSC_OJP_G925FOJP3COJ1_Arabic_5.1.1_new CSC_OJP_G925FOJP3COJ1_Arabic_5.1.1_200M And try to flash the first one as CSC, If failed then flash the second one After you got the working file, Download this: G925FXXU3COJ1_OJP3COJ1_Arabic_5.1.1_With_OI5_Hidde n and reflash the phone with both files as PDA + CSC this should fix your phone and install the latest version on it |
The Following 3 Users Say Thank You to Mr.Firmware For This Useful Post: |
11-19-2015, 14:22 | #3 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
Does't work for me! the same problem !! | |
12-09-2015, 19:20 | #4 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: romania Age: 47
Member: 45811 Status: Offline Thanks Meter: 5 | Quote:
thanks work very well | |
02-04-2016, 04:56 | #6 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
01-05-2017, 08:16 | #9 (permalink) |
Insane Poster Join Date: Aug 2016 Location: pakistan Age: 31
Member: 2607208 Status: Offline Sonork: 100.1674686 Thanks Meter: 26 | tested version 100% working g925f 5.0.2 version https://samsung-firmware.org/downloa...G925FAUT1AOCN/ g925f 6.0.1 version https://samsung-firmware.org/downloa...G925FOXA3DPAD/ |
