10-22-2015, 18:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Z3x hardware issue box getting extremely hot |
10-23-2015, 11:29 | #5 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Don't Open Or Do Anything Contact Ur Re Seller For Replace... 6 Months Warranty Came With Box....... After Open Warranty Void ...... Re Seller Contact Main Distributor & Team For Replace Your Case.... Or You Can Simply Use Pkey Reader For Your Smart Card.... Or Put Your Smart Card On Any Uni Com Base Interface.... Or You Can Select Any Uni Box Com Port While Using With Pkey Or Same Z3x Box.... |
The Following 2 Users Say Thank You to hitech care For This Useful Post: |
10-24-2015, 12:21 | #8 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | i pulled smart card from box and put in usb sim reader now card working fine . but i cant use shell is it ok if i reinstall window where to download latest update without shell please let me know |
10-24-2015, 17:15 | #9 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Can I use GPG dragon rj45 port with z3x I got all z3x cables but I have lost z3x box but smart card still working perfectly throw USB interface . Please explain me with screen shot or video help |
10-24-2015, 19:46 | #10 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Srry I Think Dragon Having Diff. Pinout.... This Is Uni Com Box Pinout Check Other Boxes You Have Which Having Same Pinout You Can Use. Let Me Help You. Z3X Easy Jtag Asansam NCK Avengers SE Tool Octopus Infinity & Many More Are Uni Com Based Boxes Now Days Mostly Running Boxes Are Uni Com Pinout Based Boxes.... You Can Use Any Of The Above Or Other Same Pinout Base Which You Have... BR. Hi-Tech Care | |
The Following User Says Thank You to hitech care For This Useful Post: |
10-24-2015, 21:35 | #11 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | I have volcano ,miracle ,atf Each box has rj45 which will work Last edited by khanzada606; 10-24-2015 at 21:36. Reason: 4'5'6 is empty pins ? Only 5 pin works ? |
