12-02-2016, 01:17 | #1 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Unlock Samsung Galaxy SOL Cricket Wireless SM-J320AZ Z3X Box 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SM-J320AZ Software version: 27.1 Searching Samsung modem... detected COM47 Reading phone info... ok Model: SM-J321AZ AP version: J321AZTUU1APD1 CSC version: J321AZAIZ1APD1 CP version: J321AZTUU1APD1 Product code: SM-J321AZDZAIO Phone SN: R28H33KASXK Unique number: CQN00EFFAC4B123 Reading IMEI... ok IMEI: XXXXXXXXXXXXXXXX (SIGN: OK) Reading data from phone... ok Unlocking... ok Rebooting phone... ok Unlock done Done with Samsung Tool PRO v.27.1 Z3X Power!! |
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
01-04-2017, 19:05 | #2 (permalink) |
Freak Poster Join Date: Jul 2007 Location: USULUTAN, EL SALVADOR. Age: 47
Member: 545374 Status: Offline Thanks Meter: 34 | hi i need help whith this model no unlock Searching Samsung modem... detected COM283 Reading phone info... Ok Model: SM-J320AZ AP version: J320AZTUU2APJ2 CSC version: J320AZAIO2APJ2 CP version: J320AZTUU2APJ2 Product code: SM2J320AZWZAIO Phone SN: R28H41DGTQY Unique number: CQ300E173684333 Reading IMEI... Ok IMEI: 356519071443260 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 any solution |
01-04-2017, 23:09 | #4 (permalink) | |
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
http://forum.gsmhosting.com/vbb/f898.../#post11927305 | |
01-16-2017, 01:50 | #5 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Read Codes no need Roots Code: UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J320AZ Software version: 27.4.2 Searching Samsung modem... detected COM78 Reading phone info... Ok Model: SM-J320AZ AP version: J320AZTUU2APJ2 CSC version: J320AZAIO2APJ2 CP version: J320AZTUU2APJ2 Product code: SM2J320AZWZAIO Phone SN: R28H52H9G0L Unique number: CQ300A4C3D3E353 Reading IMEI... Ok IMEI: 356519075000116 (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: C4 09 99 7B ED B4 E4 9A 79 04 61 77 02 B1 62 D0 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 38472793 NET lock: 96069280 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.4.2 |
01-16-2017, 02:15 | #7 (permalink) | |
