12-03-2021, 07:43 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | SM-N970U spr error to unlock idea [Answered] To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To unlock using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock SPR via Server NEW' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock SPR via Server NEW Selected model: SM-N970U Software version: 43.19 Checking Login and Password... OK Balance: 29 crd. You have 29 credit(s) left. This operation takes 10 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N970U Android version: 11 PDA version: N970USQS7FUI6 CSC version: N970UOYN7FUI6 Phone version: N970USQS7FUI6 Product code: SM-N970UZSASPR CSC country code: USA CSC sales code: SPR Carrier ID: SPR Phone SN: R58MA0S4C6B IMEI: 358819102062859 HW version: REV1.0 RF cal date: 2019.10.03 Chip name: SM8150 Modem board: SM8150 Security patch: 2021-10-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading IMEI... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Checking network lock status... UNKNOWN Reading data from phone... error (1.0.0.5.3) Reboot your phone and try again Done with Samsung Tool PRO v.43.19 |
