Old 07-28-2017, 05:03   #1 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 260
[Help] Samsung Note 5 (N920P) detected sim, full signal network, cannot make fone cal
[Help] Samsung Note 5 (N920P) detected sim, full signal network, cannot make fone call or receive fone incoming,
anybody can help me, try reset EFS but not success
downgrade, upgrade firmware and modem but not work
Old 07-28-2017, 05:06   #2 (permalink)
Member: 2185549
Thanks Meter: 535
press *#0011# and post screenshot
Sent from my Nexus 5 using Tapatalk
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 07-28-2017, 06:39   #3 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 260
here sir
Old 07-28-2017, 08:09   #4 (permalink)
Feiselski's Avatar
Member: 2583091
Thanks Meter: 413
Bro Certificate is marked as "Pass"
here sir
So flash a combination file then check if the network is working in the combination firmware, if it is working then flash a 4 file stock firmware.
Old 07-28-2017, 08:16   #5 (permalink)
Member: 2185549
Thanks Meter: 535
here sir
that means ur cert is ohkay that problem usually happens wen ur cert is faulty so wat u nred to do is check if ur imei is blacklisted in ur country if not thn flash combination and reset efs if its blacklisted try to get another cert to fix it
Old 07-28-2017, 08:38   #6 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 260
i dont have cert file for N920P
Old 07-28-2017, 09:13   #7 (permalink)
Member: 2185549
Thanks Meter: 535
i hapen to have back ups that can help u but u dd not use the same box u are using i have efs qcn and nvm but i dd not back up wid z3x cud u be havn anyother box that supports samsung i convert them fr u but brfre u write mine u have to backup ur efs and everythn u can read frm the phone using z3x
Old 07-28-2017, 15:34   #8 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 260
i have backup efs, with z3x
Old 07-28-2017, 15:58   #9 (permalink)
Member: 2185549
Thanks Meter: 535
u have that very back up or another backup frm another phone that was working
Old 07-29-2017, 07:08   #10 (permalink)
Member: 2727335
Sonork: marten
Thanks Meter: 13
Samsung j510gn no signal even i search the signal.someone cann help me pls
Old 07-29-2017, 08:04   #11 (permalink)
Member: 2185549
Thanks Meter: 535
is imei clear and normal orr
Old 07-29-2017, 08:05   #12 (permalink)
Member: 2727335
Sonork: marten
Thanks Meter: 13
Imei no problem ma bro
Old 09-06-2017, 17:55   #13 (permalink)
Member: 331337
Thanks Meter: 72
Hi im in uk and i have n920p . I removed frp lock but can not connect it to network. It shows out of service area and emergency calls only. Please help
The Following User Says Thank You to twin army For This Useful Post:
Old 09-06-2017, 19:51   #14 (permalink)
Member: 2707459
Thanks Meter: 31
The problem is qcn, i m sure. Seek qcn for u phone and repair it. It Will work
The Following User Says Thank You to kanokaiser For This Useful Post:
Old 09-07-2017, 03:29   #15 (permalink)
2111002640's Avatar
Member: 2487960
Thanks Meter: 260
do you have it??? can you share it for me ???
Page generated in 0.24648 seconds with 8 queries
