01-26-2021, 15:37 | #1 (permalink) | ||
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Online Thanks Meter: 214 | G955USQS8DTI5 after unlock network problem ! [Answered] between cdma and automatic but stuck on cdma , also mipi fail on service menu unlock info Quote:
01-27-2021, 07:57 | #3 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
In case you have the mipi fail damaged in service mode watch this video and follow the procedure repairing the mipi, install the combination binary 8 for g955u and proceed to repair the mipi, in case the procedure fails and you are unable to repair the mipi if you have a qcn file for g955u u8 try to write it see if the network works in case it is not successful unfortunately the problem is hardware COMBINATION_FA70_G955USQU8ATG1 Download https://androidfilehost.com/?fid=8889791610682947207 How To Fix Mipi Device Failed G955U All Binary Without Box or tools | |
The Following User Says Thank You to amleto90 For This Useful Post: |
01-27-2021, 10:35 | #4 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,053 | https://wiki.z3x-team.com/index.php?...redits_Pricing Attention 2!!! Before Do any unlock you have to check Cert pass and mipi device. You have to check this to avoid complain about not netowrk. Type: .*#0011# mipi device fail - result no network mostly hardware problem. |
