Old 05-21-2022, 12:47   #1 (permalink)
Member: 216446
Thanks Meter: 220
g973f unlock help [Solved]
UNLOCK INSTRUCTIONS:
To read security codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button, select 'Unlock via server ...' algo,
write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server [UPLOAD 2021]
Selected model: SM-G973F
Software version: 44.4
Checking Login and Password... OK
Balance: 27 crd.
You have 27 credit(s) left. This operation takes 8 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G973F
Android version: 12
PDA version: G973FXXUEHVC6
CSC version: G973FOVFEHVC6
Phone version: G973FXXUEHVB9
Product code: SM-G973FZWDTCL
CSC country code: Portugal
CSC sales code: TCL
Carrier ID: TCL
Phone SN: RF8M505FZLF
IMEI:
HW version: MP 0.700
RF cal date: 20190501
Chip name: EXYNOS9820
Modem board: SHANNON5000
Security patch: 2022-03-01
Boot Warranty bit: 0
SIM State: ABSENT,ABSENT
Initialization zTool Loader... OK
Running zTool, please wait... OK
Loading... OK
Initialization zTool... OK
Reading lock state... error (0.2.-1)
Done with Samsung Tool PRO v.44.4 [SM-G973F,Read Codes via Server [UPLOAD 2021]]
Old 05-21-2022, 13:16   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Hello. Currently this bit supported via root algo only.
Old 04-30-2024, 11:11   #3 (permalink)
Member: 299773
Thanks Meter: 16
G973F u16 rooted . how to unlock with z3x ?
Old 04-30-2024, 11:31   #4 (permalink)
Member: 299773
Thanks Meter: 16
Balance: 7 crd.
You have 7 credit(s) left. This operation takes 5 credits. Continue? Yes
Reading phone info... OK
Reading IMEI... OK
Model: SM-G973F
Android version: 12
PDA version: G973FXXSGHVI4
CSC version: G973FOVFGHVI4
Phone version: G973FXXSGHVI4
Product code: SM-G973FZKDVD2
CSC country code: Germany
CSC sales code: VD2
Carrier ID: DBT
Phone SN: RF8M63X6T2E
IMEI: 356928*********
RF cal date: 20190626
Security patch: 2022-09-01
Boot Warranty bit: 1
SIM State: ABSENT,ABSENT OK
Reading IMEI... OK
Checking Super user right... true
Root version: 27.0:MAGISKSU
Checking data... OK
Searching server... OK
Checking server answer... OK
Data preparation... OK
Executing 1st step... error (6 2.7.9)
Rebooting phone... OK
Done with Samsung Tool PRO v.45.14 [SM-G973F,Unlock]
Old 04-30-2024, 11:38   #5 (permalink)
Member: 299773
Thanks Meter: 16
Balance: 7 crd.
Reading IMEI... OK
Model: SM-G973F
Android version: 12
CSC sales code: VD2
Carrier ID: DBT
Reading IMEI... OK
Checking data... OK
Old 04-30-2024, 11:58   #6 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Balance: 7 crd.
Reading IMEI... OK
Model: SM-G973F
Android version: 12
CSC sales code: VD2
Carrier ID: DBT
Reading IMEI... OK
Checking data... OK
Hello. Security patch: 2022-05-01 and newer currently not supported.
The Following User Says Thank You to Z3X For This Useful Post:
Old 04-30-2024, 14:06   #7 (permalink)
Member: 299773
Thanks Meter: 16
This phone is rooted. Is there another way to unlock? with z3x ?
Old 04-30-2024, 14:12   #8 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Currently not supported.
Old 04-30-2024, 14:30   #9 (permalink)
Member: 299773
Thanks Meter: 16
Not even with this method? because it is rooted ؟
unlock regional lock via server or read code via server 2023 ??
Old 04-30-2024, 15:05   #10 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,104
Read codes not working with knox 1. About unlock region - insert sim and press unlock, in case if phone region locked - you can try.
Old 04-30-2024, 15:56   #11 (permalink)
Member: 299773
Thanks Meter: 16
Region lock .
unlock regional lock via server ؟
File Type: jpg Screenshot_20240329-190708_Bixby Voice.jpg (92.2 KB, 4 views)
The Following User Says Thank You to armin666 For This Useful Post:
Old 04-30-2024, 17:01   #12 (permalink)
Member: 299773
Thanks Meter: 16
Operation: Unlock Regional Lock
Software version: 45.14
Balance: 17 crd.
You have 17 credit(s) left. This operation takes 8 credits. Continue? Yes
Reading IMEI... OK
Model: SM-G973F
Android version: 12
CSC sales code: VD2
Carrier ID: DBT
IMEI: 3569**********
SIM State: REGIONAL_LOCKED,ABSENT
Checking SIM status... OK
Initialization... OK
Reading lock state... [0] ... OK
Waiting for server answer... OK
Unlocking... OK
Checking unlock status... OK Unlock done!
Done with Samsung Tool PRO v.45.14 [SM-G973F,Unlock Regional Lock]
Page generated in 0.19324 seconds with 10 queries
