01-31-2015, 17:17 | #17 (permalink) | |
Freak Poster Join Date: May 2011 Location: United Kingdom
Member: 1574069 Status: Offline Thanks Meter: 32 | Skype Quote:
Thanks | |
01-31-2015, 19:05 | #18 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Thanks to a user who reached out to me on Skype (don't know if you want your name mentioned on here or not, so I'll keep you anonymous for now) here's the file to wipe the "EE" lock on the Note 4 lineup: Note4PersistWipe Flash this in Odin under the AP/PDA tab. Don't forget to please hit thanks if this helped you out! |
The Following 15 Users Say Thank You to ecs87 For This Useful Post: |
02-06-2015, 16:27 | #19 (permalink) |
Freak Poster Join Date: Aug 2004 Location: romania Age: 44
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | please can you make a .tar file for G800F too? i have one G800f with the same problem. can you compile a file to solve that problem. thanks!! |
02-07-2015, 23:35 | #21 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Sorry for the delay. Someone with a clean G800F can contact me Monday afternoon via Skype or email. I'll give them a file to make a Odin flashable tar which should be able to wipe the lock on your G800F. |
02-09-2015, 17:56 | #22 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | me again hi, ecs87, i managed to find a working G800F. can you send that file you're talking about to my mail adress or post it here so i can fix the other one?? thank you ! |
02-10-2015, 17:23 | #24 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I need someone to download the app Storage Partitions and tell me the mmcblk numbers of persist and persdata (you'll need to go to menu>advanced to see this information). I'll be able to proceed with making the file. |
02-10-2015, 18:42 | #26 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I wouldn't want to risk it. I'm not sure if Odin would flash it will all zeros and even if it was able to, the persist partition may be faulty if you injected it with null. I want to give as "stock" of a solution as possible. Side-effects are what I do not want to create. |
The Following User Says Thank You to ecs87 For This Useful Post: |
02-10-2015, 23:20 | #27 (permalink) | |
Junior Member Join Date: Dec 2014
Member: 2318602 Status: Offline Thanks Meter: 11 | Quote:
I mean dd'ing the right partition would be a universal fix | |
02-10-2015, 23:35 | #28 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Flashing the file via Odin is an even easier fix. It doesn't even require root AND there is no way to mess up writing the data to the partitions because Odin handles the loading for you. I'm not by any means saying "DO NOT TRY IT", just pointing out some things |
02-11-2015, 17:06 | #29 (permalink) |
No Life Poster Join Date: Sep 2002 Location: India
Member: 15238 Status: Offline Thanks Meter: 128 | as soon as phone was connected to wi-fi (phone sensed the source of internet) ... and the playstore was accessed, the old culprit screen came back. Any remedy suggested? |
02-11-2015, 17:23 | #30 (permalink) | |
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
If you're still getting the error do the steps above again, but quickly out the phone into dm mode and repair the imei. If it's linked to the imei then it'll be fine after you repair it. | |
