Old 01-21-2017, 00:56   #1 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Galaxy Note 4 Verizon SM-N910V FRP Samsung Account Lock Removal Bypass HELP
Hi guys! I currently have a Galaxy Note 4 for Verizon SM-N910V. The phone is Samsung Account locked. I already bypassed the Samsung Account and I can actually use my own Samsung Account on the phone. The problem is that I can not remove the Samsung Reactivation Lock on the phone. I tried removing the Samsung Lock with the Z3X box using model numbers G920V and G920P but none of them worked on the N910V. I even flashed the phone with the Combination files and tried the box unlock again but i could not remove the Samsung Lock. I can use the phone but the Samsung Reactivation Lock is still there. I was searching on the forums but there is nothing clear or concrete. Any suggestions guys?? Please helpppp!
Old 01-21-2017, 01:24   #2 (permalink)
Member: 2444830
Thanks Meter: 162
yeah unfortunately none of these tools support QUALCOMM phone with reactivation lock and I can't think of nothing else.......
The Following User Says Thank You to JT man For This Useful Post:
Old 01-21-2017, 01:29   #3 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Other posts talk about doing something after flashing combination files. But nothing clear. There are even people thanking the member for the solution. But it was all by private messaging. I tried contaction the member but his inbox is full and not accepting more Pm's.
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Old 01-21-2017, 01:41   #4 (permalink)
Member: 2444830
Thanks Meter: 162
I also remember too that after flashing combo try to setup a new Samsung if it will let you but I really think that was for earlier ota's....
Sent from my iPhone using Tapatalk
Old 01-21-2017, 01:46   #5 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
The setup wizard is already bypassed. I already got the phone to accept my Samsung Account. The problem is that the Samsung Activation is still activate and I can not deactivate it even when my Samsung Account is in the phone.
Old 01-21-2017, 01:53   #6 (permalink)
Member: 2444830
Thanks Meter: 162
Yes I know, you already explain in the first post but I did had success one time flashing combo firmware and was able to setup a Samsung account then I flash stock firmware and factory reset and Samsung was no longer there but I believe with newer update is not possible so....
Sent from my SM-N930T using Tapatalk
Old 01-21-2017, 01:58   #7 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
I actually have Lollipop 5.0.1 on the phone.
Old 01-21-2017, 02:02   #8 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
When i flashed the Combination files the phone was not asking for a Samsung Account. The Account was there in settings but i could not access it.
Old 01-21-2017, 02:04   #9 (permalink)
Member: 2444830
Thanks Meter: 162
I'm not sure which phone it was, I believe S5 or S4 but that was my experience....
Old 01-21-2017, 02:08   #10 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
I am surprised that a solution has not been found for this phone.
Old 01-21-2017, 02:09   #11 (permalink)
Member: 2444830
Thanks Meter: 162
Same here, either it is privately or it hasn't come down pipeline yet....
Old 01-21-2017, 02:15   #12 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Yeap, i guess nobody likes to give away their research work for free. I do not mind to give away my solution work. I think that that is what this forum is all about.
Old 01-21-2017, 03:03   #13 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
By the way, I am on Lollipop 5.0.1 N910VVRU2BOG5 firmware version
Old 01-21-2017, 05:11   #14 (permalink)
Member: 1912082
Thanks Meter: 46
Its paid solution by Samsung official tool, pm me if you are interested
Old 01-21-2017, 05:23   #15 (permalink)
Member: 254271
Thanks Meter: 17
Brief description for what I have to do. Modify the build.prop
Sent from my LG-K428 using Tapatalk
The Following 2 Users Say Thank You to WChriseg For This Useful Post:
Page generated in 0.24487 seconds with 8 queries
