Old 03-28-2018, 22:03   #1 (permalink)
Member: 2604559
Sonork: Ventaslaredo
Thanks Meter: 127
Galaxy s8 (T-mobile) network unlock Done // select SM-G955U1
1- Enable ADB
2- enable the last option in *#0808#
3- install the drivers.
4- in my case., only works SSM-G955U1 to unlock this tmobile phone i dont know why., but works!
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will appear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Unlocking using Server:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever:
5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Unlock
Selected model: SM-G955U1
Selected port: COM86 SAMSUNG Mobile USB Serial Port
Software version: 31.0
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G950U
Android version: 7.0
Product code: SM-G950UZVATMB
Phone version: G950USQS2BRB1
PDA version: G950USQS2BRB1
CSC version: G950UOYN2BRB1
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J41ZRKBE
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2018-02-01
RF cal date: 2017.04.16
IMEI: 35775308XXXXXXX
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Rebooting to upload... OK
Searching Ramdump interface... COM17 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Start... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.31.0
The Following User Says Thank You to ventaslaredo For This Useful Post:
Old 03-29-2018, 01:22   #2 (permalink)
Member: 180903
Sonork: 100.1637253
Thanks Meter: 67
Software version 31.0????
Old 03-29-2018, 21:11   #3 (permalink)
Member: 180903
Sonork: 100.1637253
Thanks Meter: 67
Need support proof inorder not to brick the phone
Old 03-30-2018, 11:43   #4 (permalink)
elaygenov's Avatar
Member: 1690263
Thanks Meter: 71
unlocking with credit no need root just enable the last option in *#0808#
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12193 seconds with 7 queries
