Guide Direct Unlock sprint Galaxy S4/S5 1 use dfs to send spc xxxxxx and pwd 2012112120131219 after device unloked whit dfs close ports on dfs and go to z3x progrram select port and direct unlock log Operation: Unlock Selected model: SPH-L720 Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 990003487765444 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
also works on other variants UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N900V Selected port: COM97 SAMSUNG Mobile USB Serial Port , Software version: 21.0 Reading phone info... Reading IMEI... OK IMEI: 990004662318504 Reading security... new type Bypassing... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.21.0 |
log |
this method work in S6 edge sprint? |
N915P Sprint I tried this method on N915P it failed why? I don't know the MSL/SPC Code for N915P, and it is not 000000, because all zeroes are by default for Verizon phones, and you don't need to unlock Verizon as they come unlocked. Now back to my Note Edge from Sprint, I used DFS many years ago and also CDMA workshop however, I don't have either of them a PRO version. So, I used the password and phone is unlocked but to fully unlock you must send SPC/MSL also. Since I don't have that not useful. Tried many methods by rooting the phone and try using terminal and command as getprop ril.MSL. Failed. Tried to use alogcat and got nothing. Z3X Pro 21.1 it fails bypass security.... error OCTO.. does it unlock and says unlock but actually still locked. Sorry bro no luck for me. Hope to hear others if they could do it. |
Does it work for the domestic carriers? (T-mobile or Att)? Or only international? Sent from my iPhone using Tapatalk |
Hi, I have done s4 and note 3... Any other models that can be unlocked for domestic gsm use? Sent from my iPhone using Tapatalk |
Ok, thank you.. As for the mega.. Can you point me to the direction? Sent from my iPhone using Tapatalk |
We need to downgrade modem as well? What settings do we change in the hidden menu? Sent from my iPhone using Tapatalk |
