10-16-2019, 10:23 | #1201 (permalink) |
Crazy Poster Join Date: Sep 2016 Location: Swat, Pakistan
Member: 2619617 Status: Offline Thanks Meter: 9 | dear team; i am facing a problem with z3x samsungtool pro. I wanted to repair imei of my j200f but it gives this error. I don't know what this error is. kindly if anyone have solution for this, please post it here. thanks REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-J200F Software version: 37.0 Waiting ADB device... OK Reading phone info... Model: SM-J200F Android version: 5.1.1 PDA version: J200FXXS3ARI1 CSC version: J200FOJV3AQL1 Phone version: J200FXXU3AQE1 Product code: SM-J200FZDDKSA CSC country code: KSA CSC sales code: KSA Phone SN: R58H53J8JPR IMEI: HW version: MP 0.300 RF cal date: 20160520 Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-08-01 Boot Warranty bit: 1 SIM State: NOT_READY,NOT_READY Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... Exception: Cannot open file 'C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\Data\zTool_Exynos '. The system cannot find the file specified Done with Samsung Tool PRO v.37.0 |
The Following User Says Thank You to ilyaseen For This Useful Post: |
10-16-2019, 10:42 | #1202 (permalink) |
Insane Poster Join Date: Jun 2016 Location: pakistan
Member: 2592409 Status: Offline Thanks Meter: 15 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Repair Selected model: SM-J260F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-J260F Android version: 8.1.0 PDA version: J260FXXU3ASF1 CSC version: J260FOJM3ASF2 Phone version: J260FXXU3ASF2 Product code: SM-J260FZDDKSA CSC country code: KSA CSC sales code: KSA Phone SN: R28M21*** IMEI: 35************ HW version: MP 0.500 RF cal date: 20190225 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... modem not supported Searching server... OK Checking available files... not found compatible file Try downgrade modem if possible Done with Samsung Tool PRO v.38.2 |
The Following User Says Thank You to Abdulrehmman For This Useful Post: |
10-16-2019, 15:29 | #1205 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2499218 Status: Offline Thanks Meter: 44 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-M105F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-M105F Android version: 9 PDA version: M105FDDU2BSH2 CSC version: M105FODM2BSH2 Phone version: M105FDDU2ASH1 Product code: SM-M105FDADINS CSC country code: India CSC sales code: INS Phone SN: RZ8M51Z02RL IMEI: 359330052077532 HW version: REV0.2 RF cal date: 20190514 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-08-01 SIM State: LOADED,LOADED Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
The Following User Says Thank You to abbasdvd For This Useful Post: |
10-16-2019, 15:30 | #1206 (permalink) | |
Member: 2499218 Status: Offline Thanks Meter: 44 | statos ng no network Quote:
10-25-2019, 18:21 | #1209 (permalink) |
Junior Member Join Date: Oct 2019 Location: Greece
Member: 2931873 Status: Offline Thanks Meter: 1 | I have a Samsung S7 Edge SM-G935F Running Android Oreo 8.0.0 Build Number G935FXXS4ESC1 Baseband G935FXXU4ESAE Please Support for IMEI Repair and Patch Net Certification Until now z3x tool can not repair..."try to downgrade modem if possible" is the log |
The Following User Says Thank You to georgegino For This Useful Post: |
10-26-2019, 15:34 | #1210 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1629204 Status: Offline Thanks Meter: 2 | lg z3x 2g_3g i think has a bug when ever i want to unlock unlock.app phones it shops responding i tried with 3 computers (lg h872at) |
The Following User Says Thank You to scjia For This Useful Post: |
10-27-2019, 20:08 | #1212 (permalink) |
Junior Member Join Date: Jun 2014 Location: iran BND
Member: 2198707 Status: Offline Thanks Meter: 3 | a205f no fix imei eror (0 15) im change the imei Code: Operation: Repair Selected model: SM-A205F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 9 PDA version: A205FXXU2ASJ1 CSC version: A205FODM2ASJ1 Phone version: A205FDDU2ASE7 Product code: SM-A205FZKGINS CSC country code: India CSC sales code: INS Phone SN: RZ8M63THRRL IMEI: 359290067**** HW version: REV0.3 RF cal date: 20190628 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-10-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... error (0 15) Reboot phone and try again. Check ADB drivers, USB cable. Don't use USB Hubs If this repeated then reflash phone and make factory reset. Done with Samsung Tool PRO v.38.2 |
11-09-2019, 08:04 | #1213 (permalink) |
Junior Member Join Date: Feb 2019 Location: India
Member: 2892330 Status: Offline Thanks Meter: 5 | samsung sm - m307f combination flash failed samsung sm - m307f combination flash failed pit error when flash combination on sm - m307f please find out and help me |
