10-21-2020, 00:40 | #1291 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1221809 Status: Offline Thanks Meter: 0 | J7 Prime G610M with software version g610mubs8cth1 unlock via server error Selected model: SM-G610M Software version: 41.2 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G610M Android version: 8.1.0 PDA version: G610MUBS8CTH1 CSC version: G610MUWM8CTH1 Phone version: G610MUBS8CTH1 Product code: SM-G610MZKACGU CSC country code: Guatemala CSC sales code: CGU Phone SN: RXXXX51XXXX IMEI: 35377XXXXX80XXX HW version: MP 0.200 RF cal date: 20180124 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2020-08-01 Boot Warranty bit: 0 SIM State: READY Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (0 5.2) Reboot phone and try again. Check ADB drivers, USB cable. Don't use USB Hubs If this repeated then reflash phone and make factory reset. I have tried both old and mar 2020 options, several ports and cables, have factory resetted, flashed, checked IMEI and serial (both are the same ones which are also writter on back cover) and still refuses to unlock. |
10-29-2020, 09:31 | #1293 (permalink) |
Insane Poster Join Date: Jun 2016 Location: pakistan
Member: 2592409 Status: Offline Thanks Meter: 15 | G615F patch not working REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-G615F Software version: 41.4 Waiting ADB device... OK Reading phone info... Model: SM-G615F Android version: 7.0 PDA version: G615FXXU2ARH2 CSC version: G615FODD2ARH2 Phone version: G615FXXU2ARG2 Product code: SM-G615FZDDPAK CSC country code: PAKISTAN CSC sales code: PAK Phone SN: R28K33K7Q0L IMEI: 35..... HW version: MP 0.200 RF cal date: 20181106 Chip name: MT6757 Modem board: MT6757 Security patch: 2018-08-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Checking Super user right... true Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Preparation of data... OK Writing data to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.41.4 |
11-02-2020, 09:17 | #1294 (permalink) |
Freak Poster Join Date: Jan 2011 Location: india
Member: 1492933 Status: Offline Sonork: 100.1646938 Thanks Meter: 56 | how to unlock please help me UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A217F Software version: 41.6 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A217F Android version: 10 PDA version: A217FXXU3ATI7 CSC version: A217FOJM3ATI8 Phone version: A217FXXU3ATI7 Product code: SM-A217FZKGMID CSC country code: Iraq CSC sales code: MID Phone SN: RF8N80438TX IMEI: 352363869489662 HW version: MP 0.500 RF cal date: 20200803 Chip name: EXYNOS850 Modem board: SHANNON318 Security patch: 2020-09-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM17 Checking diag port... OK Searching Samsung modem... detected COM18 Searching server... OK Checking server answer... modem not supported Try downgrade modem if possible Done with Samsung Tool PRO v.41.6 |
11-03-2020, 08:24 | #1298 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | hecking Login and Password... OK Ballance: 24 crd. You have 24 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J600FN Android version: 10 PDA version: J600FNXXS9CTI2 CSC version: J600FNOVF9CTI2 Phone version: J600FXXS9CTI2 Product code: SM2J600FZKNCNX CSC country code: Romania CSC sales code: CNX Phone SN: RF8K82LR17Y IMEI: 357062092870657 HW version: REV0.3A RF cal date: 20180824 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2020-09-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM97 Checking diag port... OK Searching Samsung modem... detected COM94 Searching server... OK Checking server answer... modem not supported Try downgrade modem if possible Done with Samsung Tool PRO v.41.7 |
11-03-2020, 14:05 | #1299 (permalink) |
Freak Poster Join Date: Dec 2018 Location: Harare Zimbabwe Age: 33
Member: 2883035 Status: Offline Thanks Meter: 84 | HELLO EVERYONE NEED HELP ON J701F PATCHING NETWORK ERROR If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch Certificate Selected model: SM-J701F Software version: 41.6 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 9 PDA version: J701FXXS9C*** CSC version: J701FOLB9C*** Phone version: J701FXXS9C*** Product code: SM-J701FZDDTHL CSC country code: THAILAND CSC sales code: THL Phone SN: RV8K5064YET IMEI: 3************ HW version: MP 0.400 RF cal date: 20180514 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2020-09-01 Boot Warranty bit: 1 SIM State: ABSENT,LOADED Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (5 4.1) Unlock method is not supported, use another method Done with Samsung Tool PRO v.41.6 |
11-03-2020, 15:39 | #1300 (permalink) |
Member: 2883035 Status: Offline Thanks Meter: 84 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch Certificate Selected model: SM-J701F Software version: 41.7 Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 9 PDA version: J701FXXS9C*** CSC version: J701FOLB9C*** Phone version: J701FXXS9C*** Product code: SM-J701FZDDTHL CSC country code: THAILAND CSC sales code: THL Phone SN: RV8K5064YET IMEI: 3************ HW version: MP 0.400 RF cal date: 20180514 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2020-09-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (5 4.1) Unlock method is not supported, use another method Done with Samsung Tool PRO v.41.7 |
11-03-2020, 17:29 | #1301 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | z3x bug report i hd been experiencing this bug like forever.. PLEASE FIX https://mega.nz/file/jI9mTZTZ#KV5AJK...iffMK9Srem3Scs |
11-03-2020, 20:54 | #1302 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2524571 Status: Offline Thanks Meter: 0 | Reading data from phone... error (5 4.1) Operation: Repair Selected model: SM-A530W Software version: 41.7 Waiting ADB device... OK Reading phone info... Model: SM-A530W Android version: 9 PDA version: A530WVLSDCTH1 CSC version: A530WOYVDCTH1 Phone version: A530WVLSDCTH1 Product code: SM-A530WZKAKDO CSC country code: Canada CSC sales code: KDO Phone SN: R58KC0NNDPX IMEI: 359585052807333 HW version: REV0.3A RF cal date: 20181207 Chip name: EXYNOS7885 Modem board: SHANNON327 Security patch: 2020-09-01 Boot Warranty bit: 1 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (5 4.1) Unlock method is not supported, use another method Done with Samsung Tool PRO v.41.7: |
11-04-2020, 10:14 | #1304 (permalink) | |
Member: 2883035 Status: Offline Thanks Meter: 84 | Anything yet team need your help Quote:
The Following User Says Thank You to ellisony For This Useful Post: |
11-05-2020, 04:01 | #1305 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | please add g985f bit 4 , not unlock Operation: Read Codes via Server Selected model: SM-G985F Software version: 41.8 Checking Login and Password... OK Ballance: 27 crd. You have 27 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G985F Android version: 10 PDA version: G985FXXS4ATGB CSC version: G985FOXM4ATGB Phone version: G985FXXU4BTH5 Product code: SM-G985FLBLXEF CSC country code: France CSC sales code: XEF Carrier ID: PCT Phone SN: R58 IMEI: 3537 HW version: REV0.5 RF cal date: 20200707 Chip name: EXYNOS990 Modem board: SHANNON5123 Security patch: 2020-08-01 Boot Warranty bit: 0 SIM State: ABSENT,NOT_READY Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM14 Checking diag port... OK Searching Samsung modem... detected COM13 Searching server... OK Checking server answer... modem required There is no information about this firmware on the server. Done with Samsung Tool PRO v.41.8 |
