[Help] Unlock m2520 hello z3x team, i need your help. i have in my hands phone samsung m2520, this log: Quote:
Read Full Flash from phone and upload in file server and post link this. |
how read flash? i work with cable usb, you have diagram for rj45? with cable usb no read firmware, i need picture for build cable, thank you |
you need to do , volume key down+9 and conect usb cable, setup drivers, choise in speed window of programm USB and press read. |
blang: Quote:
i have problem for read flash, this log Quote:
Use new version for read code and post result. |
Last version on support: 2G tools v3.4.0015 Selected model: M2520 Selected com port: COM13 Selected speed port: USB Phone must be ON! Please, connect phone Entering TestMode... OK SW: 520VIIH3 Langpack: Not found langpack ! IMEI: 35820403022821 S/N: RSJS935361 HW-> MP 0.600 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 089 Flash Device ID: 887e0000 Flash size: 67108864 Bytes Flash sectors: 256 sectors Bluetooth ID: 00265f-6afdaa Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE This is sha-1 code - wait for decrypt Decrypted time: 99 sec Read info - ok Elapsed time: 111 second, sw ver: 3.4.0015 not worked |
unlocking reser code to 00000000 and not possible calculate. |
i have the same problem,because i no read the rellease for this new update...:eek: i'm waiting one solution for this problem.. Tankhs Z3x Team |
Use 2G tools 3.4.0018 version: 1. Use function unlock. 2. use function read code or enter 00000000 for unlock. |
This Info work fine...See the log down: Quote:
Tankhs alex999_ and Z3x Team for solve this problem! |
