12-31-2010, 12:22 | #3 (permalink) |
Freak Poster Join Date: May 2008 Location: india Age: 40
Member: 776810 Status: Offline Sonork: 100.1627706 Thanks Meter: 19 | user lock how to reset user lock code............. which cable use in c3303 |
The Following User Says Thank You to firose4u For This Useful Post: |
05-27-2011, 08:00 | #4 (permalink) |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | Autoignition cable for c3303 |
The Following User Says Thank You to rajeshchiyyan For This Useful Post: |
05-30-2011, 10:23 | #6 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | Updating Samsung c3303 Champ Flash/Firmware Updating Samsung c3303 Champ Flash/Firmware Prepare the Phone Driver for Flashing. 1. Turn OFF Phone. 2. Connect MicroUSB to Champ. 3. Press Volume Down + Lock key then connect USB Cable to PC 4. Install driver (Driver can be found on C3300K_Flash_loader_7.4.4_SSG_v0.5 folder, 52xdfu)(Manual install it using device manager) When installed, get ready. Re flashing 1. Run Flash loader 7.4.4_SSG_v0.5.exe 2. Click SET MODEL -> Select C3300_LIBRE_Setting_v02.mdl 6. Click Start 7. Turn OFF Phone. 8. Connect MicroUSB to Champ. 9. Press Volume Down + Lock key then connect USB Cable to PC 10. Wait the flashing finished. (During the Flashing, your phone is off, then when the flashing is finish, you can see the your phone is charging. 11. Remove from USB. Turn on the Phone, Check if success, -if failed, try nyu ulit ang mga steps. Good Luck. Do at your own risk. Not my responsibility for the Possible Damage can be made to your Phone direct download link 1. Flasher: http://www.4shared.com/file/PNYp0EsM/C3303KJPJI2.html pass: 'www.gem-flash.com' 2. Firmware: http://www.4shared.com/file/8S8zLiSd/C33...SG_v0.html 3. MicroUSB 4. C3303k Samsung Champ Phone 5. Prepare Phone Driver enjoyyyyy mohsin from south africa |
The Following 5 Users Say Thank You to trust4eve83 For This Useful Post: |
02-06-2012, 23:04 | #11 (permalink) |
No Life Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 771795 Status: Offline Sonork: 771795 Thanks Meter: 120 | i cant solve usb d/l mood problem when i connect it by press vol plus and lock key it connect then disconnect from download mode and blinking. |
07-24-2012, 01:40 | #12 (permalink) |
Major Poster Join Date: May 2012 Location: Colombo Age: 42
Member: 1760941 Status: Offline Sonork: 100:1616842 Thanks Meter: 1 | Any new firmwares for C3303K? Can anyone explain me the different between firmwares C3303KJPJI2 & C3303I-DXKB1? I am a newbie. So, don't get mad at me if it was a stupid question. |
07-24-2012, 01:44 | #13 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Yogyakarta, ID
Member: 1786327 Status: Offline Sonork: 100.1621394 Thanks Meter: 58 | Quote:
Wrong files will make the phone not working, can be repaired by flashing with correct firmware. C3303K-JP-JI2 Phone type - Region - Release date / version | |
The Following User Says Thank You to yogyaphone. For This Useful Post: |
07-24-2012, 13:16 | #14 (permalink) | |
Member: 1760941 Status: Offline Sonork: 100:1616842 Thanks Meter: 1 | Quote:
I am from Sri Lanka. For which version should I go for? Will the European versions work for me or Do I have to go for any Asian version? (I searched for Sri Lankan version, but there was nothing) | |
08-02-2012, 15:54 | #15 (permalink) | |
Freak Poster Join Date: May 2007 Location: Kumasi;Ghana\west africa Age: 38
Member: 510345 Status: Offline Thanks Meter: 40 | c3330 dead flashing i have c3330 any software for flashing? it died when flashing with Z3x box Quote:
The Following User Says Thank You to ASIEDU ANNOR For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
