Old 06-17-2012, 14:17   #1 (permalink)
Member: 1051354
Thanks Meter: 41
< How to ROOT i9000 2.3.6 for unlock >
DOWNLOAD THIS FILE: CF-Root Download
  1. Extract the rooted kernel from the ZIP file you downloaded. You will get one file after extracting: CF-Root-XX_OXA_JVU_2.3.6-v4.3-CWM3RFS.tar.
  2. Launch Odin3 on your computer.
  3. Turn off your phone.
  4. Reboot your phone into download mode by holding down the Volume Down key and the OK button simultaneously, then pressing the Power button.
  5. Once the phone is in download mode, connect your phone to your computer via the USB Cable.
  6. Odin3 should be able to detect your phone. If so, the ID:COM field in Odin3 will turn yellow. If not, your phone was not properly detected and you should not proceed.
  7. In the Odin3 window, click the PDA button.
  8. Select CF-Root-XX_OXA_JVU_2.3.6-v4.3-CWM3RFS.tar.
  9. Under “Options” in Odin3, make sure “Repartition” is not checked.
  10. Click the Start button in Odin3. The program will start flashing the update file to your phone.
  11. Your phone will automatically reboot after Odin3 has finished flashing the update.
  12. Disconnect the phone from the computer only after it has completely rebooted.
Your Samsung Galaxy S GT-I9000 should now be rooted. You’re now running Android 2.3.6 XXJVU firmware with root access on your Samsung Galaxy S GT-I9000.
NOW YOU CAN UNLOCK WITH Z3X NO MORE NEED DOWNGRADE TO 2.3.5 OR LOWER!!
Hit thanks if you like
The Following 2 Users Say Thank You to 2k9-Phonez For This Useful Post:
Old 06-17-2012, 19:23   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
The easy tool is unlockroot
Old 06-17-2012, 20:33   #3 (permalink)
Member: 257142
Thanks Meter: 59
but this tool unlockroot not support root i9100 v2.3.6 for root
Old 06-20-2012, 13:19   #4 (permalink)
Member: 894650
Thanks Meter: 11
i rooted as u explained but now phone is blinking on "glaxy S GT-I9000".
what can i do now ?
pls help me.
Old 06-20-2012, 13:23   #5 (permalink)
Member: 1051354
Thanks Meter: 41
Full flash with this firmware:
Samsung Galaxy S GT-I9000 : Install Android 2.3.6 Gingerbread Value Pack
Then try again.
Old 06-20-2012, 14:35   #6 (permalink)
Member: 894650
Thanks Meter: 11
Then try again.
now it does't "on" the phone.
pls help me
Old 07-24-2012, 10:26   #7 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
thanks my phone just turns on and off now any ideas ????.........................br
Old 07-24-2012, 11:03   #8 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
i have just flashed it now its ok again but wouldnt recomending using that method for root ...........................br
Old 07-24-2012, 23:09   #9 (permalink)
Member: 150570
Thanks Meter: 52
I know you solved your problem by flashing, next time, just remove your battery for a few minutes. Somtimes it works and sometimes not. If it works, it saves on reflashing.
Check this post and you'll see a solution. > [HOWTO] [REF] (un)root your SGS I9000 the easy way (keep all your data) (Eclair 2.1) - xda-developers
Old 08-04-2012, 22:10   #10 (permalink)
Member: 1506502
Worked for me.
Thanks a lot my friend!
Old 08-17-2012, 18:32   #11 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Thanks Meter: 219
Thumbs down
Bulsh.. is not working ! Don't post fake solution
Old 08-17-2012, 18:46   #12 (permalink)
Member: 727888
Thanks Meter: 219
Why Z3X supporter don't help us and provide the right solution for root and unlock this phone ?
B.R.
Old 01-10-2013, 13:32   #13 (permalink)
totalmanish's Avatar
Member: 336192
Thanks Meter: 53
my 9000 is now blinking..........
Old 02-18-2013, 13:48   #14 (permalink)
lxa786's Avatar
Member: 163725
Thanks Meter: 137
use this file
CF-Root Download
Old 03-24-2013, 12:36   #15 (permalink)
Member: 496384
Thanks Meter: 23
its done thank you a lot
The Following User Says Thank You to cheikh-gsm For This Useful Post:
Page generated in 0.28511 seconds with 9 queries
