how to unlock a687 hey, i am kinda confused, how to unlock samsung sgh-a687 with new tools? |
1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB part of 2in1 cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes |
which model should i select ? and which version should i use for z3x software? |
phone not detecting at all... not even when i press 1+0 .... |
First in ur list programe select ur phone model and do what he said if not working must be dowloeud ur driver |
there is no option to choose qualcomm in software Count supported models - 223 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... detected (COM6) Model: SGH-A687 SW: A687.002 IMEI: 35186204062476/7 Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... |
please send me drivers? |
all drives installer on support. don;t use windows or se drivers for this phone., only with samsung drivers you can unlock this phone. |
i did download new drivers and some thing, not connecting, please send full guide step by step which cable too use : which 3g tool version to use : because 8.6 don't work for me and i have 9.4 installed and i also have 1.0.3 but it don't have a687 model support. send link for correct drivers : so i can be sure i have correct one installed |
use 9.4 version. and read manual. |
can someone help me out here? thanks |
Bro did you ever get this one unlocked. I got one also and had to look into buying a code on ebay for it. Im sure by now the 1 & 0 keys are totally worn out, maybe it my pc, but i tried on another pc but no connection same way. |
well my friend put the code in for me, you have to do it really fast, when u pressing 1+0 ,remove the battery, because you have to take out the battery for it to detect :) so: 1 . remove battery 2. press 1+0 & plug in cable 3. press unlock 4. get your unlock code 5 . smile :)) |
