Old 05-27-2011, 12:38   #1 (permalink)
abid77's Avatar
Member: 221644
Thanks Meter: 18
Question How to unlock Samsung E2230
How to unlock Samsung E2230 with Z3x box?
Old 06-02-2011, 10:16   #2 (permalink)
nobal1976's Avatar
Member: 71190
Sonork: 100.1580485
Thanks Meter: 87
slect e2330 in z3x use e210 usb cable and read codes
here is log:
Selected model: E2330
Selected com port: COM12
Selected speed port: 921600
Phone must be OFF
Press * and connect phone by cable
Connecting to Device... OK
Wait for decrypted code... OK
Decrypted time: 81 sec
[PCK]:#0141*00000000#
[NCK]:#0111*47137872#
[SCK]:#0121*00000000#
[SPCK]:#0133*00000000#
[MCK]:#0199*93891246#
Read info - ok
Elapsed time: 100 second, sw ver: 3.5.0018
The Following User Says Thank You to nobal1976 For This Useful Post:
Old 10-18-2012, 13:04   #3 (permalink)
Member: 1652459
Thanks Meter: 22
select e2330 in z3x use e210 usb cable and read codes
if not work, try with safe mode.
In my case working,with safe mode, here you have log:
Selected com port: COM4
Phone must be OFF
Press * and connect phone by USB cable
Sending preloader ... OK
Sending loader ... OK
Damping ... OK
Calculated code please wait...
Decrypted time: 54 sec
This is zone 0
[PCK]:Enter this without sim #0141*00000000# this is sim lock
[NCK]:Enter this without sim #0111*1342xxxx# this is net lock
[SCK]:Enter this without sim #0121*00000000# this is CP lock
[SPCK]:Enter this without sim #0133*00000000# this is SP lock
[MCK]:Enter this without sim #0199*9621xxxx# this is Master(freeze) code
safe read info - ok
Elapsed time: 141 second, sw ver: 3.5.0038
Old 12-09-2012, 16:45   #4 (permalink)
Member: 1677667
Sonork: janjua28
i have this problam someone halep me..............
Selected model: E2230
Selected com port: COM7
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
After power on phone - connect to UART cable
Timeout
Deactivate MSL - fail
Read info - fail
Elapsed time: 70 second, sw ver: 3.5.0040
Old 12-10-2012, 19:29   #5 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Timeout
Read info - fail
No Wait Hit URT Cable 3300k Solved Your Problem...
BR.
Arsalan gsm2000.
The Following 2 Users Say Thank You to .::MASTER ALONE::. For This Useful Post:
Old 12-11-2012, 10:07   #6 (permalink)
Member: 99768
Thanks Meter: 35
BR.
Arsalan gsm2000.
Why don't u read carrefully the first post? Whe are talking about Samsung E2230 (E210 usb pinout) and not about E2330 (C3300 micro USB connectot). The USB connector is not the same at these models. Regards!
Old 12-15-2012, 19:46   #7 (permalink)
Member: 178186
Thanks Meter: 2
If you see "Not Yet personalised":
Insert not accepted sim, enter subset lock [SCK] and will see "Personalisation canceled"
On NsPro is "subset lock" or on Z3X is [SCK] or CP lock.
#0121*subset lock code#
Old 01-30-2013, 16:29   #8 (permalink)
Member: 230005
Thanks Meter: 14
in z3x select e2330 speed 460800 and safe info
The Following User Says Thank You to d81cristian For This Useful Post:
Old 02-11-2013, 13:53   #9 (permalink)
Member: 201764
Thanks Meter: 76
unlock e2230 safe
this is right procedure ,tested by me today,after a 1 hour of searching,
tnks
Old 02-12-2013, 20:02   #10 (permalink)
Member: 314780
Thanks Meter: 12
tnks
thanks i confirm here the log :
Elapsed time: 8 second, sw ver: 3.5.0040
Selected com port: COM10
Phone must be OFF
Damping ... OK
Decrypted time: 5 sec
This is zone 0
[NCK]:Enter this without sim #0111*00000000# this is net lock
[MCK]:Enter this without sim #0199*00000000# this is Master(freeze) code
safe read info - ok
Elapsed time: 128 second, sw ver: 3.5.0040
Old 03-14-2013, 16:58   #11 (permalink)
stargsm_ro's Avatar
Member: 44085
Thanks Meter: 123
After 1000 tries:
Selected speed port: 460800
Phone must be OFF
Damping ... OK
Decrypted time: 41 sec
This is zone 0
[NCK]:Enter this without sim #0111*95605650# this is net lock
[MCK]:Enter this without sim #0199*64903187# this is Master(freeze) code
safe read info - ok
Elapsed time: 127 second, sw ver: 3.5.0040
Thank's!!!
Old 04-16-2013, 10:12   #12 (permalink)
Member: 921420
Thanks Meter: 28
what u need to do:...
after ****in' up the IMEI tried to repair it with "Custom"...didn't work so...
i've selected E2350 and...
OTP repair...
Selected model: E2350
Selected com port: COM3
Phone must be OFF
Erasing ... OK
Writing ... OK
Repair OTP - ok
Elapsed time: 17 second, sw ver: 3.5.0040
THEN IMEI repai with "Custom"...
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Search diag port... OK (COM26)
Phone SN: RV1D10YZXQ
Deactivate MSL - OK
Phone OLD IMEI: 35704204597955/00
Repair - fail
Elapsed time: 49 second, sw ver: 3.5.0040...it says repair fail but it lies like a motha****a
and then READ codes...
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Deactivate MSL - OK
Decrypted time: 94 sec
This is zone 0
[NCK]:Enter this without sim #0111*42097239# this is net lock
[MCK]:Enter this without sim #0199*49798944# this is Master(freeze) code
Read info - ok
Elapsed time: 141 second, sw ver: 3.5.0040
i've only used the usb cable
Old 06-01-2013, 09:51   #13 (permalink)
Member: 1253967
Thanks Meter: 2
E2230 unlock
standard USB cable, press and hold *, select model E2530, press SAFE INFO button
Selected model: E2530
Phone must be OFF
Damping ... OK
Decrypted time: 30 sec
This is zone 0
[NCK]:Enter this without sim #0111*3426XXXX# this is net lock
[MCK]:Enter this without sim #0199*31756935# this is Master(freeze) code
safe read info - ok
Elapsed time: 119 second, sw ver: 3.5.0040
The Following User Says Thank You to albinutza For This Useful Post:
Old 06-07-2013, 12:14   #14 (permalink)
Member: 1469112
Sonork: lacramioru
Phone must be OFF
Damping ... OK
This is zone 0
safe read info - ok
thank you bro! real useful info!
Old 06-12-2013, 11:08   #15 (permalink)
u2k
Member: 853470
Sonork: KSMGSMLAB
great ideas ever. sofigsm and others THANKS
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.26949 seconds with 9 queries
