i dont understand same binary number for restore? hi i dont understand what this means, same binary number if i want to restore a firmware>? i have G935pvps4bqc1 ? so do i download g935pvpy4apl6 or g935pvps4apj2 ? i tried G935PVPS4APK1_SPT4APK1_SPR_Sprint_USA_6.0.1 and odin says Auth failed ? |
here is your file. Enjoy |
thanks, but i cant downgrade?? |
That is the 6.0.1 Marshmallows firmware |
What do you intend to do on this phone? Why do you want to downgrade? Also, show logs of operations with tool. |
im trying to unlock it, i unlocked it and it worked for a little bit and now it says " roaming indicator off" it wont let me get into the roming options , there not there anymore.. nor the apn settings.. i tried network reset, SCRTN reset, rerooted and reunlocked, and Enabled gcf.. so i think i may of currupted the firmware.. whats best reflash the QC1 and do it again or downgade ? |
ok now odin accepted the PJ2 ill root and unlock and let you guys know how it goes.. thanks |
<ID:0/040> Added!! <ID:0/040> Removed!! <ID:0/004> Added!! <ID:0/004> Removed!! <ID:0/047> Added!! <ID:0/047> Removed!! <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin engine v(ID:3.1100).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> emmc_appsboot.mbn <ID:0/004> NAND Write Start!! <ID:0/004> lksecapp.mbn <ID:0/004> xbl.elf <ID:0/004> tz.mbn <ID:0/004> hyp.mbn <ID:0/004> devcfg.mbn <ID:0/004> pmic.elf <ID:0/004> rpm.mbn <ID:0/004> cmnlib.mbn <ID:0/004> keymaster.mbn <ID:0/004> apdp.mbn <ID:0/004> msadp.mbn <ID:0/004> cmnlib64.mbn <ID:0/004> sec.dat <ID:0/004> NON-HLOS.bin <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img.ext4 <ID:0/004> persist.img.ext4 <ID:0/004> modem.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> adspso.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> cache.img.ext4 <ID:0/004> meta-data/ <ID:0/004> meta-data/download-list.txt <ID:0/004> FAIL! <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1 |
Open the Settings app. In the Wireless & Networks section, touch the More item. Choose Mobile Networks. . Remove the check mark by the Data Roaming option. If you cannot perform these operations because the settings are not there anymore, I will advice that you restore to it's original version to fix the errors. Once, unlocked, it will still remain unlocked even if you restore to original version |
went to 99% and Failed????? |
if failed on Bootloader? so no downgrade for this guys? why did you tell me to downgrade guys?? i hope i didnt mess up anything |
QC1 failed to?? im choosing Home CSC and using odin 3 10.7 ? <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin engine v(ID:3.1100).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> emmc_appsboot.mbn <ID:0/004> NAND Write Start!! <ID:0/004> lksecapp.mbn <ID:0/004> xbl.elf <ID:0/004> tz.mbn <ID:0/004> hyp.mbn <ID:0/004> devcfg.mbn <ID:0/004> pmic.elf <ID:0/004> rpm.mbn <ID:0/004> cmnlib.mbn <ID:0/004> keymaster.mbn <ID:0/004> apdp.mbn <ID:0/004> msadp.mbn <ID:0/004> cmnlib64.mbn <ID:0/004> sec.dat <ID:0/004> NON-HLOS.bin <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img.ext4 <ID:0/004> persist.img.ext4 <ID:0/004> meta-data/ <ID:0/004> meta-data/fota.zip <ID:0/004> FAIL! <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
Give teamviewer id and pass or anydesk id. |
