I flashed two times with two different unlock patch files.But phone is not unlocked. I flashed with two patch unlock files but when I insert sim usim locked is shown.I mean phone is not unlocked.I flashed with these two files 1)U300_V10H-OFF-SEP-28-2006-H3G-IT-UNLOCK-PATCH-RUS-UKR-V-1-0.crp 2)U300_V10H-OFF-SEP-28-2006-H3G-IT-UNLOCK-PATCH.crp. What can I do for unlock for my U300 Handset?Is those patch files are any problem?Can you please explain how to unlock this u300 hand set?Its urgent any body please help me? Here is the flash log. v.1.3.0 supported models: 51 andrew_tm 2008(c) ;) Reading file as U300... Ok Patch Flash File: U300-V10h-OFF-SEP-28-2006-H3G-IT Lang(ver 1.0) Mode: Normal Model: U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 35928800040414-3 BlueTooth Address: 00:12:56:4A:93:06 Phone Code: 0000 Elapsed: 0 secs. Mode: Normal Model: U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 35928800040414-3 BlueTooth Address: 00:12:56:4A:93:06 Phone Code: 0000 Elapsed: 0 secs. NV read... NV save:..\backup\U300_359288000404143_09022009_11324 0.cnv Elapsed: 7 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Write NV... EFS Write Start... Start Write Media... Start Write Module... EFS Write Done. Flash Done. Elapsed: 853 secs. Mode: Normal Model: U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 35928800040414-3 BlueTooth Address: 00:12:56:4A:93:06 Phone Code: 0000 Elapsed: 0 secs. Start repair media... Change country to: Italy Phone reboot! Elapsed: 25 secs. Mode: Normal Model: U300 SW Version: U300-MSM6250A-V10h-SEP-28-2006-H3G-UK IMEI: 35928800040414-3 BlueTooth Address: 00:12:56:4A:93:06 Phone Code: 0000 Elapsed: 0 secs. Start repair media... Change country to: United Kindom Phone reboot! Elapsed: 6 secs. |
READ THIS THREAD http://forum.gsmhosting.com/vbb/show...02&postcount=7 |
I have the same problem, i thing Z3x not solution for this model |
Step unlock LG-U300 by patch with z3x LG Tool Step 1 Download this file in support "U300_V10H-OFF-SEP-28-2006-H3G-IT-UNLOCK-PATCH" and flash your phone Step 2 After successful flash firmware insert the original Sim card H3G (or test Sim card) and power phone on. In the phone menu select Tools, and launch the Unit converter. After starting the phone transferred Unit converter, here at this moment in time we need to remove the battery, change the H3G (or Sim test card) to the card operator's beloved (no PIN code) and insert the battery back, all these manipulations need to have done in about 10 seconds. Step 3 If you have done everything correctly, you successfully register your phone in your network operator and will bring you joy until the next turn off the phone, after which you will need to do the procedure again, starting with the Step 2 position. Goodluck;) BR Star75 vn_mobile |
If u want to full unlock U300 in this monent, so need to use the other tool :) |
