i have proplem with my z3x box it can open normal but after i make read code or unlock or flash or any thing it give's me cyrtical fail http://www.4shared.com/photo/gQK_ce7i/z3x_error.html z3x error - Download - 4shared |
usb cable not connected. driver not installed. phone must be on BR TEJARAM |
you're problem with what phone bro,. please detail here... B.R Patrick Carter |
the box give error and close fast |
dreiver was good and usb is good i have more 2 boxes and working v.good |
same problem with me box open nomral and choose model after try unlock or flash give me that error ..... i have another box work very good no problem --- i think card problem or box hardware problem any one have solution |
it's sure card proplem cause i try to put it in another box and give same error |
same problem with me |
I also never used to undergo such a. bro, try uninstall and clean driver, restart PC and install again..:) B.R Patrick Carter |
in same time i have more than one box work fine its card or box driver |
i remove the card and put in another working box same problem 100% card problem how to update card firmware ? |
Open shell, click on the "Settings and card tools", then click on "Run hardware Wizard", then follow the steps. |
This looks more like an OS issue, why don't you try a different pc? or re installing windows at least? |
Thank you, werato but this is the image that appears when you follow the steps http://www12.0zz0.com/2013/07/18/21/901777246.jpg |
