01-21-2016, 08:32 | #10 (permalink) |
Freak Poster Join Date: Jun 2012 Location: India Pune
Member: 1778852 Status: Offline Sonork: 100.1641316 Thanks Meter: 231 | Samsung SM-A800F Imei 35000000000006 Fix Problem Solved By Z3X Box BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-A800F Software version: 24.1 Waiting ADB device... OK Reading phone info... Model: SM-A800F Android version: 5.1.1 Product code: Phone version: A800FXXU1AOJ1 PDA version: A800FXXU1AOJ1 CSC version: A800FODD1AOJ1 CSC country code: India CSC sales code: INS HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization AT RIL... OK Checking for compatible phone and cert Phone KEY ID: 0838 Checking certificate file... OK KEY ID: 0838 Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.24.1 |
The Following User Says Thank You to Gsm Narendra For This Useful Post: |
03-29-2016, 17:11 | #13 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2380428 Status: Offline Thanks Meter: 0 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-A800F/DS Software version: 24.9 Waiting ADB device... OK Reading phone info... Model: SM-A800F Android version: 5.1.1 Product code: Phone version: A800FXXU1AOK5 PDA version: A800FXXU1AOK6 CSC version: A800FODD1AOK4 CSC country code: India CSC sales code: INS HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Initialization AT RIL... AT RIL stopped, restarting... Checking for compatible phone and cert Phone KEY ID: Exception: '' is not a valid integer value Done with Samsung Tool PRO v.24.9 pls help me |
