02-23-2010, 07:30 | #17 (permalink) |
Major Poster Join Date: Mar 2008 Location: PHILIPPINES
Member: 732120 Status: Offline Thanks Meter: 28 | unlock it using c260 cable..... procedure: 1-use power supply using 3.7 volts [IMG][/IMG] 2-attach c260 cable and power on phone [IMG][/IMG] 3-press unlock [IMG][/IMG] lock globe b4 now ok with smart [IMG][/IMG] |
The Following 5 Users Say Thank You to powex_88 For This Useful Post: |
02-23-2010, 07:39 | #18 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: Split / Zagreb, Age: 15
Member: 1212935 Status: Offline Sonork: cylone team Thanks Meter: 122 | Quote:
http://forum.gsmhosting.com/vbb/showthread.php?t=931441 | |
The Following User Says Thank You to Cyclone Team<3 For This Useful Post: |
02-23-2010, 10:35 | #19 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | yes new version with USB cable is verry good, with power suply you can kill many phone, some with forget and puting 12v, or some time the + touch -, but it's sure it's a good sharing whit C260 cable , i5700 vs C260 it's like android vs crap phone Best Regards, JAVA Good. |
The Following User Says Thank You to JAVA Good For This Useful Post: |
02-23-2010, 13:11 | #20 (permalink) |
Registered User Join Date: May 2007
Member: 512495 Status: Offline Thanks Meter: 22 | powex is best,, they can unlock the i5700 w the cable of c260 plus 3.7 volts in the power supply..for me its very dangerous that powex using power supply BUT the i5700 was unlock,, so there is no problem abwt the power supply w 3.7 volts wc is the voltages supply of the phone... shock it & re charge it |
The Following User Says Thank You to donzkygallendo For This Useful Post: |
02-23-2010, 14:13 | #21 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | flash your phone with this method, and after customer come to your shop, you have the choise, 1) flashing your phone with C260 cable and don't move, 2) or see your customer take what he need on your shop for free, there is pic of my first i5700 unlocking : IMAG0083.jpg and IMAG0081.jpg @powex_88 have anny solution for modify the power suply or made a power with USB cable BUT when the + touch - the power stop ? Best Regards, JAVA Good. |
02-24-2010, 05:25 | #22 (permalink) |
Member: 512495 Status: Offline Thanks Meter: 22 | I have tryd 5 times using c260 cables with the power supply 3.7 volts all successfull,. But i dont using cable c260 for flashing i5700,,only for unlocking,,, but for now z3x version 2.3.50 samsung smartphonetool supports usb cable,,, tnx u bro... Shock it & recharge it |
02-24-2010, 13:06 | #25 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | TO do it with Z3X without soldering : *#7284# choose Modem in both *#9090# - choise 1 BR! |
The Following 11 Users Say Thank You to equinoks For This Useful Post: |
02-27-2010, 20:09 | #27 (permalink) |
No Life Poster Join Date: Mar 2003 Location: paris Age: 44
Member: 24284 Status: Offline Thanks Meter: 56 | a diffrent B7300 i try with this one (gt-b7300)pinout posted but not work ,i try to unlock user code.look at board it sems different then other pic posted before. gnd is the same rx and tx don"t work.a new pin maybe? |
The Following User Says Thank You to street For This Useful Post: |
**Samsung Softbank 820sc Tested Unlocked by Z3x Box** | codni | Z3X-Team Products | 4 | 02-23-2015 11:36 |
First in nueva ecija philippines 730sc unlock by z3x box | MARCO_LEI24 | Z3X-Team Products | 13 | 04-30-2009 14:59 |
**Samsung 730SCHI6 Unlocked by Z3X Box**[captured by Dsc-t77] | Nonoyxp | Z3X-Team Products | 9 | 04-30-2009 02:49 |
cu920 dont unlock by z3x | cityyemen | Z3X-Team Products | 1 | 04-18-2009 06:10 |
