12-06-2017, 10:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | sm-g928 6.0.1 without root unlock done :P To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G928A Selected port: COM1210 SAMSUNG Mobile USB Serial Port Software version: 29.6 Searching Samsung modem... detected COM1209 Reading phone info... OK Model: SM-G928A AP version: G928AUCS4CPK5 CSC version: G928AUCS4CPK5 CP version: G928AUCU4APK1 Product code: SM-G928AZKEPRT Phone SN: R38G70AH4JW Unique number: 06157DF69A237606 Reading IMEI... OK IMEI: 3535130@@@@@@@@ (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.6 |
The Following User Says Thank You to lerner_ For This Useful Post: |
