Old 08-11-2017, 10:33   #1 (permalink)
Member: 2746416
Thanks Meter: 4
G920F - Checking NV data... error Security damaged (1)
Hello. I have Samsung G920F with broken IMEI. I want to restore IMEI from original documents. While doing Repair operation in Samsung Tool PRO I have error: Checking NV data... error Security damaged (1). I tried to Write NV Data from backups and from NV files from internet. Writing was done successfully, but still during Repair operation it is the same error. Phone is rooted. Please help me.
  BACKUP INSTRUCTIONS:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Read EFS' button to read backup or 'Write EFS' to restore.
  6. Press 'Write CERT' to restore certificates.
  7. Press 'Write NV DATA' if you need to restore NV backup.
    Read certificate operation:
  2. Connect the phone to PC with USB cable.
  3. Check Samsung modem in device manager, install drivers if needed.
  4. Press 'Read CERT' button to read certificates.
Operation: Repair
Selected model: SM-G920F
Software version: 29.0
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Waiting ADB device... OK
Reading phone info...
Model: SM-G920F
Android version: 7.0
Product code:
Phone version: G920FXXU5EQCD
PDA version: G920FXXS5EQG1
CSC version: G920FXEU5EQF2
CSC country code: UK & IRE
CSC sales code: XEU
HW version:
Phone SN: 00000000000
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-07-01
RF cal date:
IMEI:
Checking Super user right... true
Reading NV data... OK
Done with Samsung Tool PRO v.29.0
Old 08-11-2017, 11:06   #2 (permalink)
Murat Bekar's Avatar
Member: 2088
Sonork: 100.1630154
Thanks Meter: 57
flash with 6.0.1 then try again
regards
Old 08-11-2017, 13:50   #3 (permalink)
Member: 2746416
Thanks Meter: 4
I downgraded to 6.0.1 but this error still appears:
Operation: Repair
Software version: 28.9
Model: SM-G920F
Android version: 6.0.1
Product code:
Phone version: G920FXXU5DPL3
PDA version: G920FXXU5DQA7
CSC version: G920FXEG5DQA2
CSC country code: Germany
CSC sales code: XEG
HW version:
Security patch: 2017-01-01
RF cal date:
IMEI:
Done with Samsung Tool PRO v.28.9
Old 08-11-2017, 14:09   #4 (permalink)
Temporary banned !!
Member: 568521
Thanks Meter: 240
Operation: Repair
Model: SM-G920F
Product code:
CSC sales code: XEU
HW version:
RF cal date:
IMEI:
Add me on skype, i will help you, skype id = handyline1
Old 08-11-2017, 15:52   #5 (permalink)
Member: 2746416
Thanks Meter: 4
Thanks sharef! For others with that kind of problem - it was problem with NV Data - after writing correct package of NV Data, the repair of imei was successfully.
Old 08-19-2017, 20:09   #6 (permalink)
Member: 11273
Thanks Meter: 14
Please share the "correct package of NV Data"
Hi serwistk,
I have the same Problem with the same model. Please share the "correct package of NV Data" with me.
thank you in advanced
best regards
Old 12-06-2017, 09:51   #7 (permalink)
Member: 2746416
Thanks Meter: 4
Sorry for reply time, but forums e-mail notification mechanism is not working for me, so I did not notice that someone replied to my thread.
That was "SM-G920F_12-5-2017_16-55-0__RF8G30J9HTD_nv_data . rar". For some reason I am not allowed to post links and attaching files to message (it always ends with upload fail error), so I am posting link below to my Google Drive, with spaces around dots, so You need to remove two spaces...
goo . gl/WidMjU
Old 12-06-2017, 09:56   #8 (permalink)
Member: 1845731
Thanks Meter: 741
no need to dwngrd ver sollution is here just use octopus box
Operation: Repair
Model: SM-G920F
Product code:
CSC sales code: XEU
HW version:
RF cal date:
IMEI:
its working on ver 7 no need to dwngrd ver
http://forum.gsmhosting.com/vbb/f453...-done-2284579/
Page generated in 0.19223 seconds with 8 queries
