i9100 flashing Pass but wont pass thru the 1st logo hye..ive got dosen i9100 have a problem cant pass thru the i9100 logo then it will restart automatically..ive been try so many firmware but the problem still exist |
brother change audio codec ic near sim connector...........maybe ur problem solve |
hard reset after flash |
Phone should go into recovery mode using Volume up + home & power Select data wipe/factory reset & this should cure the problem. I have seen this on many I9100's & this usually fix the problem |
flash boot then reflash it again |
I had a i9100 today which has been flashed and it was restarting. When performed a wipe data the restaring has stopped and phone passed the Logo without any problems. Very good solution which works 100%. |
Wipe data/factory reset and wipe cache. IF THAT DOESN'T WORK, MOVE ON WITH THE GUIDE [GUIDE] Fix an unflashable or soft bricked GSII - xda-developers |
password is **************** you will find the flasher inside and please post back your feed back. wbr super boy24 |
