05-31-2012, 01:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | i9100 unknown imei i have one i9100 with unknown imei and baseband i have try to repair imei and i have this log: Searching Samsung USB Modem... Detected (COM91) Model: GT-I9100 SW: ERROR IMEI: 000000000000000 Done with Samsung Tool ver 12.5 Android Version: 2.3.3 Model: GT-I9100 Product Code: Unknown Phone Version: Unknown PDA Version: I9100BVKH1 CSC Version: I9100AMNKH1 IMEI: Unknown Checking ROOT... FALSE Rooting Phones, Please Wait... OK Checking ROOT... TRUE Reading Data From Phone... OK Writing NV Data To Phone... OK Rebooting Phone... OK Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 12.5 what can i do? thanks |
05-31-2012, 15:19 | #2 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | atualizaei after my i9100 had this error in odin would like information to reach a solution to this problem thank you all! |
05-31-2012, 16:44 | #4 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Delphi XE2
Member: 1004812 Status: Offline Thanks Meter: 152 | 1. Power on phone. 2. Enable debugging on: menu>application settings>development.. 3. Connect cables and setup drivers. 4. Press Repair button. 5. Enter new IMEI and press OK if it does not help to write the full flash file dump |
05-31-2012, 21:44 | #5 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | Quote:
[ROM+Guide]Official i9100 Firmwares LPE/Q/7/2/F/S/4/7/G/9/W/D/F Download - xda-developers Install root manually. Then use Z3X version 12.1 or 12.2. Some people have used the same version as you 12.4 and it worked > so, to try and change/reinstall imei > check Unlock root as well as EFS Repair. It will show error. don't remove cable or do anything. just click on Repair as soon as phone has finished booting up. And imei repair should go through successfully. I've only worked on 12.1 and this method works every time first time and not hours later, as is the case if you check 'search' | |
The Following User Says Thank You to Phoneze For This Useful Post: |
06-06-2012, 01:19 | #8 (permalink) |
Member: 16943 Status: Offline Thanks Meter: 35 | hi some help for me? i began the post and nobody answer me? i did try to repair imei but not success, then i think i must flash the phone. i don't know if i must flash with full flash file dump (what is this?, if posible to xdo it with z3x or do i need special machine? can anybody explain me what files must i put in odin or another soft to flash the phone? the origina lversion is from orange spain BVKH1 and i can't find it can anybody helps me? thanks |
02-05-2013, 05:32 | #9 (permalink) | |
Freak Poster Join Date: Nov 2009 Location: MOROCCO
Member: 1164285 Status: Offline Sonork: 100.1648187 Thanks Meter: 296 | Quote:
no nedd repair imie or phone version just flash with original fermwar good lack | |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
