Old 12-04-2014, 02:32   #1 (permalink)
Member: 958481
Thanks Meter: 2
n900v no service
Selected model: SM-N900V
Selected port: COM705 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Searching Samsung modem... not found
Done with Samsung Tool v.18.2
Searching Samsung modem... detected COM706
Reading phone info...
Software version: =1,1
IMEI:
Product code:
Searching ADB device... OK
Model: SM-N900V
Android version: 4.4.2
Product code: Not Active
Phone version: N900VVRUCNC4
PDA version: N900VVRUCNC4
CSC version: N900VVZWCNC4
IMEI:
Phone S/N: 00000000000
Checking Super user right... true
Backuping MMCBLK... OK
Checking phone at COM705
Detected ID: 00000FF3 (MSM8974)
SW Version: M8974A-AAAANAZM-2.0.10047
Reading ESN... OK
Backuping RFNV... OK
Backuping Feature Mask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Writing data to phone... OK
Rebooting phone... OK
Waiting phone... OK
Reading QCN file... OK
Checking paths... error
Checking certificate file... OK
Model: SM-N900V
IMEI: Unknown
Bypass MSL... OK
Checking for compatible phone and cert... OK
Writing CERT... OK
Checking CERT status... OK
trying to use this on att
wrote n900q cert everything went fine but wont get signal
Old 12-22-2014, 20:59   #2 (permalink)
Member: 2107135
Thanks Meter: 6
I got the same thing happening to me too. Tried all the old fixes and still nothing.
Nothing seems to work.
Old 12-23-2014, 00:18   #3 (permalink)
Member: 2076039
Thanks Meter: 648
Repair the MEID. It needs to match the IMEI on CDMA based phones for CERT to pass ;-)
Old 12-23-2014, 00:39   #4 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Download DFS Tool or CDMA Workshop (I use paid version)
Connect phone send 16digit password ...
and make sure "R-UIM Config" is set to "R-UIM only"
Problem solved ....
The Following User Says Thank You to jusmejose For This Useful Post:
Old 12-23-2014, 00:40   #5 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Not true ... Just make sure "R-UIM Config" is set to "R-UIM only"
Old 12-23-2014, 16:23   #6 (permalink)
Member: 2076039
Thanks Meter: 648
On every CDMA based phone that ive had to repair the IMEI on the MEID must match the IMEI. As soon as I write the MEID, cert passes upon reboot.
The Following User Says Thank You to ecs87 For This Useful Post:
Old 12-23-2014, 18:22   #7 (permalink)
jusmejose's Avatar
Member: 1081371
Thanks Meter: 720
Not on my side I never had issues with IMEI Cert not passing ... Only with the G900V yeah I have to match the MEID with the IMEI ... But on the N900V I never had issues with it ...
Old 12-23-2014, 19:05   #8 (permalink)
Member: 2076039
Thanks Meter: 648
Interesting. Maybe its something they added in 4.4.2/4.4.4?
Old 03-03-2015, 04:21   #9 (permalink)
Member: 2297291
Hey guys im having the same problem everything went smoothly, i wrote the n900 cert onto the n900v and it has a clean imei but it wont get service, it says EMERFENCY CALLS ONLY. When i type *#0011# into the phone it says "IMEI CERT: PASS" but it also says "SERVICE: LIMITED" . And when i typed in *#06# the meid is the same as the imei so why is it still not working ?! Please help!!! I wrote the cert with the z3x box. ANY HELP WOULD BE APPRECIATED! Thanks!
Old 03-03-2015, 10:07   #10 (permalink)
Member: 1057346
Sonork: 1606384
Thanks Meter: 10
before unlocked read first original qcn and after that unlocked procedure reset efs and write cert n900 if no service write original qcn ..mybe it help sir ..
Old 03-05-2015, 04:16   #11 (permalink)
Member: 2297291
Hey, yes I backed up the qcn before clearing the efs and after writing the cert I wrote the same qcn back on the phone but it still doesn't work?
Page generated in 0.18530 seconds with 8 queries
