02-03-2017, 07:33 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | samsung s7 edge frp lock failed after download this file phone show this Imgur: The most awesome images on the Internet Imgur: The most awesome images on the Internet Imgur: The most awesome images on the Internet UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-G935FD Software version: 27.7 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDUINS Phone version: G935FXXU1APB8 PDA version: FA60_G935FXXU1APB5 CSC version: CSC country code: CSC sales code: HW version: MP 0.801 Phone SN: RZ8H70C4M7E Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160706 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 what i need to do for unlock frp on this mode |
