Old 03-20-2015, 01:07   #1 (permalink)
LCE
Member: 1969562
Thanks Meter: 4
Question i317m v4.4 unlock problem Z3x
Can not unlock N2 i317M phone, "No answer from phone". tried different computer still no luck. Can somebody help me pls? see log below
Selected model: I317M
Selected port: COM11 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Searching ADB device... OK
Reading phone info...
Model: SGH-I317M
Android version: 4.4.2
Product code: SGH-I317TSMTLS
Phone version: I317MVLUDNH2
PDA version: I317MVLUDNH2
CSC version: I317MOYADNH2
IMEI: 354845050579788
Phone S/N: R21CC1BVAGW
Checking Super user right... true
Backuping MMCBLK... OK
Checking phone at COM11
Done with Samsung Tool v.19.1
Old 03-20-2015, 02:47   #2 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Read instructions how to configure port. Then install driver if not installed. Make sure i317m is rooted.
Old 03-20-2015, 03:47   #3 (permalink)
Member: 1712020
Sonork: marko1928
Thanks Meter: 29
type *#0808# then check the modem adb mtp
Old 03-20-2015, 04:10   #4 (permalink)
gsm_rabby's Avatar
Member: 2356568
Sonork: 1663093
Thanks Meter: 126
fast cheek post carefuly
The Following User Says Thank You to gsm_rabby For This Useful Post:
Old 03-20-2015, 06:41   #5 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 288
Model: SGH-I317M
Flash 4.1.1 modem only using ODIN. Then just read codes using old security. Then flash back the 4.4.2 original modem with ODIN.
Good luck
The Following User Says Thank You to rasgula For This Useful Post:
Old 03-21-2015, 00:24   #6 (permalink)
LCE
Member: 1969562
Thanks Meter: 4
Good luck
This is good idea. I google it but someone said downgrade might be stuck on bootloader? have you ever tried downgrading? I also tried to download the 4.1.1 modem but it looks the download link not valid anymore? only 4.3 or 4.4 is ok. Does anybody have the valid link to download 4.1.1 modem? thanks
Old 03-21-2015, 02:42   #7 (permalink)
LCE
Member: 1969562
Thanks Meter: 4
Thanks to Rasgula. Downgrade to 4.1.1. Then Read the code by Z3x. Here is the log
Selected port: COM19 Z3X BOX Serial Port
Reading phone info... fail
Done with Samsung Tool v.19.0
Selected port: COM79 Qualcomm HS-USB Diagnostics 9004
Build: M9615ACEHWMAZD179550
Reading security... OK
Searching server... OK
NET lock: 42529795
Sub lock: 00000000
SP lock: 00000000
For check lock status: *#7465625#
Hopefully this can help other brothers. If someone can direct unlock the V4.4.2 please share.
Old 03-21-2015, 14:25   #8 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 288
Selected port: COM55 SAMSUNG Mobile USB Serial Port
Model: SGH-I317M
Product code: SGH-I317TSMKDO
IMEI: 35xxxxxxxxxxxxx
Phone S/N: Rxxxxxxxx
Checking phone at COM55
Detected ID: 00000FE6 (SURF9615)
SW Version: M9615A-CEFWMAZM-2.0.14159
Reading ESN... OK
Backuping RFNV... OK
Backuping Feature Mask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Writing data to phone... OK
Rebooting phone... OK
Waiting phone... OK
Model: SGH-I317M
Product code: Not Active
IMEI: Unknown
Phone S/N: Rxxxxxxxxxx
Bypass MSL... OK
Unlocking... OK
Reading QCN file... OK
Checking paths... OK
Restoring EFS Backup... OK
Restoring NV Items... OK
Restoring NV Item SIM1... OK
Restoring NV Item SIM2... OK
Restoring Provisioning Item Files... OK
Reseting... OK
Unlock done
Done with Samsung Tool v.18.8
Page generated in 0.14943 seconds with 8 queries
