10-15-2021, 21:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Initialization zTool... error (1) [Answered] To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 try all methods and fail..how ken y unlock this device? br |
10-16-2021, 14:33 | #4 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [OLD] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 Last edited by carlos32; 10-16-2021 at 14:40. |
10-16-2021, 14:34 | #5 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [Mar 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 Last edited by carlos32; 10-16-2021 at 14:41. |
10-16-2021, 14:36 | #6 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 Last edited by carlos32; 10-16-2021 at 14:42. |
10-16-2021, 14:37 | #7 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG Jan 2021] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 |
10-16-2021, 14:39 | #8 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Phone has old security. Use another method. Done with Samsung Tool PRO v.43.16 |
10-16-2021, 16:02 | #9 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 4,984 | Phone dont have screenlock? Reflash it and repeat operation. https://samfrew.com/uk/download/Gala...A202FCKH3BTF1/ |
10-16-2021, 16:02 | #10 (permalink) |
12-26-2021, 19:47 | #11 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | Code: Waiting ADB device... OK Reading phone info... Model: SM-A205YN Android version: 11 PDA version: A205YNDVU7CUI1 CSC version: A205YNLDT7CUI2 Phone version: A205YNDVU7CUI1 Product code: SM-A205YZKTVAP CSC country code: Australia CSC sales code: VAP Carrier ID: VAP Phone SN: R58M91F1P4P IMEI: 356776102288748 HW version: REV0.0 RF cal date: 20190905 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-09-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... error (1) |
12-26-2021, 22:06 | #12 (permalink) |
Junior Member Join Date: May 2010 Location: moroc
Member: 1306944 Status: Offline Sonork: 0601694737 Thanks Meter: 11 | Initialization zTool... error (1) ou have 15 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A405FN Android version: 11 PDA version: A405FNXXU3CUC4 CSC version: A405FNOXM3CUC4 Phone version: A405FNXXU3CUC2 Product code: SM-A405FZKDPHE CSC country code: SPAIN CSC sales code: PHE Carrier ID: E30 Phone SN: R58R43E88GW IMEI: 351551685481548 HW version: REV0.3A RF cal date: 20210417 Chip name: EXYNOS7904 Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.22 |
12-26-2021, 22:06 | #13 (permalink) | |
Member: 706257 Status: Offline Thanks Meter: 4,984 | Quote:
https://samfrew.com/ru/download/Gala...205YNLDT7BUB1/ | |
12-27-2021, 00:09 | #14 (permalink) | |
Member: 2119579 Status: Offline Thanks Meter: 44 | Quote:
Code: Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A205YN Software version: 43.22 Checking Login and Password... OK Balance: 7 crd. You have 7 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A205YN Android version: 10 PDA version: A205YNDVS7BUB1 CSC version: A205YNLDT7BUB1 Phone version: A205YNDVS7BUB1 Product code: SM-A205YZKTVAP CSC country code: Australia CSC sales code: VAP Carrier ID: VAP Phone SN: R58M91F1P4P IMEI: 356776102288748 HW version: REV0.0 RF cal date: 20190905 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Checking SIM status... OK Executing... OK Searching Ramdump interface... COM57 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... error (1) Could not find data. Please try again. Done with Samsung Tool PRO v.43.22 | |
12-27-2021, 09:02 | #15 (permalink) | |
