Initialization zTool... error (1) [Answered] UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 try all methods and fail..how ken y unlock this device? br |
u can try with root ? |
Hello. Can you attach all logs with all methods? |
UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [OLD] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 |
To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [Mar 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 |
UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG May 2020] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 |
UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [DIAG Jan 2021] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.16 |
UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A202F Software version: 43.16 Checking Login and Password... OK Balance: 17 crd. You have 17 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A202F Android version: 11 PDA version: A202FXXU3CUG2 CSC version: A202FOVF3CUG1 Phone version: A202FXXU3ASL3 Product code: SM-A202FZKDTCL CSC country code: Portugal CSC sales code: TCL Carrier ID: TCL Phone SN: RF8N700VR8P IMEI: 358791109323370 HW version: MP 0.300 RF cal date: 20200701 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-05-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Phone has old security. Use another method. Done with Samsung Tool PRO v.43.16 |
Phone dont have screenlock? Reflash it and repeat operation. https://samfrew.com/uk/download/Gala...A202FCKH3BTF1/ |
Code: Waiting ADB device... OK |
Initialization zTool... error (1) ou have 15 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A405FN Android version: 11 PDA version: A405FNXXU3CUC4 CSC version: A405FNOXM3CUC4 Phone version: A405FNXXU3CUC2 Product code: SM-A405FZKDPHE CSC country code: SPAIN CSC sales code: PHE Carrier ID: E30 Phone SN: R58R43E88GW IMEI: 351551685481548 HW version: REV0.3A RF cal date: 20210417 Chip name: EXYNOS7904 Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... error (1) Done with Samsung Tool PRO v.43.22 |
https://samfrew.com/ru/download/Gala...205YNLDT7BUB1/ |
Code: Operation: Read Codes via Server [UPLOAD 2021] |
