09-03-2013, 04:44 | #1 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | samsung i747m NEW SECURITY unlock done 1 problem version 4 1 2 2 here help info Code: download Stock 4.0.4 firmware Stock 4.0.4 Download Odin 3.7 Odin 3.7 1 Put phone in download mode and connect to PC (vol-+home+power) 2 extract downloaded files 3 open PDA in Odin and select the firmware 4 make sure only F. Reset time and Auto reboot are checked 5 click start to flash phone 6 Phone hangs at Samsung afterwards so do hard reset after removing and inserting battery back (vol+/Home/power) scroll with volume and confirm with power key 8 follow normal unlock procedure and unlock phone if you need to upgrade back after unlocking, firmware is here Stock ROM Firmware odim version 4.1.2 after flash done |
12-17-2013, 13:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | useless on 4.3, cant be downgraded, nothing..just 4.3, even rooted, cant unlock it.. Z3X team guys, find a solution.. Selected model: I747M Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443100 Reading security... error access denied Done with Samsung Tool v.16.6 Done with Samsung Tool v.16.6 |
12-17-2013, 21:46 | #9 (permalink) |
Major Poster Join Date: Oct 2009 Location: montreal .quebec .canada
Member: 1135872 Status: Offline Sonork: 100.1652834 Thanks Meter: 8 | have same probleme i747 m 4.3 i cant downgrade it teste many firm 4.04 ....... nothing all firm was fail |
The Following User Says Thank You to ziani For This Useful Post: |
12-18-2013, 08:26 | #10 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | Selected model: I747 Selected port: COM265 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443072 Reading security... error access denied Done with Samsung Tool v.16.1 version 4.1.2 at$t provide solution |
12-18-2013, 08:33 | #11 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote:
I am repeating again check android version.. If it is 4.3 not possible if it is 4.1.2 downgrade it and follown the instruction described on top... | |
12-18-2013, 10:38 | #14 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: INDIA
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | Quote:
http://forum.gsmhosting.com/vbb/f453...ocked-1750949/ | |
12-18-2013, 11:31 | #15 (permalink) | |
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | Quote:
bye.. | |
