J120m reset frp error [ 3/1/2016 6:52:00 PM ] Searching Samsung USB Flash Interface... detected COM28 [ 3/1/2016 6:52:00 PM ] Setup connection... OK [ 3/1/2016 6:52:00 PM ] Reading PIT from phone... OK [ 3/1/2016 6:52:00 PM ] Searching FRP lock... OK [ 3/1/2016 6:52:00 PM ] Erasing FRP... error [ 3/1/2016 6:52:00 PM ] |
Try to flash with good firmware and repeat reset frp steps. Regards Rehan Shaikh |
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 24.6 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.6 |
Operation: Reset FRP/React/EE Selected model: SM-J120M Versión de Software : 24.7 Searching Samsung USB Flash Interface... detectado COM32 Configurar conexión ... Listo Leyendo PIT desde el teléfono ... Listo Searching FRP lock... Listo Erasing FRP... error Done with Samsung Tool PRO v.24.7 |
Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 25.5 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.25.5 |
Downgrade the firmware and try it... should work. |
Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 25.8 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.25.8 |
master when you publish something that is to serve for 2016 20016 20016 eye that no longer serves ok thanks for the help read before posting |
j120m Quote:
