11-21-2016, 10:32 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | j200f frp problem i well try to flash sboot eroor Total file size: 0x85D2B7A4 (2141 Mb) Searching USB Flash interface... COM4 detected Setup connection... ok Set PIT file... ok Reading PIT from phone... ok Sending sboot.bin... error timeout Done with Samsung Tool PRO v.27.1 |
The Following 3 Users Say Thank You to G.G For This Useful Post: |
11-21-2016, 12:52 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IN INDIA
Member: 263005 Status: Offline Thanks Meter: 147 | same about me FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J200F Software version: 27.1 File analysis... ok Total file size: 0x85CA8910 (2140 Mb) Searching USB Flash interface... COM7 detected Setup connection... ok Reading PIT from phone... ok Sending sboot.bin... error timeout Done with Samsung Tool PRO v.27.1 |
The Following User Says Thank You to alimuamin For This Useful Post: |
11-21-2016, 12:59 | #3 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
flash this file then try to reset frp and post result http://d-h.st/mzL5 Last edited by Asad ali khan; 11-21-2016 at 13:04. | |
The Following User Says Thank You to Asad ali khan For This Useful Post: |
11-21-2016, 13:33 | #5 (permalink) |
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | flash only this file not full firmware Dev-Host - j200f frp.tar - The Ultimate Free File Hosting / File Sharing Service |
The Following 2 Users Say Thank You to Asad ali khan For This Useful Post: |
11-21-2016, 13:35 | #6 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | File analysis... ok Total file size: 0x008EDA30 (8 Mb) Searching USB Flash interface... COM4 detected Setup connection... ok Reading PIT from phone... ok Sending boot.img... ok Sending sboot.bin... error timeout Done with Samsung Tool PRO v.27.1 |
The Following User Says Thank You to G.G For This Useful Post: |
11-22-2016, 07:00 | #9 (permalink) |
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | i think i post wrong file wait i will post a new link without password |
04-21-2017, 13:18 | #15 (permalink) |
Major Poster Join Date: Apr 2015 Location: Bhulta,Rupgonj,N-g,Bangladesh
Member: 2380355 Status: Offline Sonork: mamun ahammed Thanks Meter: 10 | i have same problem sm j200f any one hlp |
The Following User Says Thank You to Mamun ahammed For This Useful Post: |
