11-14-2017, 16:02 | #1 (permalink) |
Freak Poster Join Date: Jul 2016 Location: U.S.A
Member: 2604559 Status: Offline Sonork: Ventaslaredo Thanks Meter: 131 | J3 emerge boost unlock done Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J327P Software version: 29.6 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU2AQI1 PDA version: FA60_J327PVPU2AQI1 CSC version: CSC country code: CSC sales code: HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2016-11-01 RF cal date: 2017.02.04 IMEI: 356964XXXXXXXXX Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.6 |
11-14-2017, 20:44 | #3 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
Unlock and reflash stock firmware Pon la combo QI1. Unlock con z3x y pon firmware original. Solo asi sale http://forum.gsmhosting.com/vbb/f453...2aqi2-2284936/ | |
The Following User Says Thank You to Alexandroid For This Useful Post: |
11-17-2017, 11:23 | #5 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | Quote:
File analysis... OK Total file size: 0x51D9EA28 (1309 Mb) Searching USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... error timeout Done with Samsung Tool PRO v.29.0 | |
01-30-2018, 01:47 | #10 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | |
