J330F unlock help Operation: Read Codes via Server Selected model: SM-J330F Software version: 29.8 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM964 Reading phone info... OK Model: SM-J330F AP version: J330FXWU1AQF9 CSC version: J330FOJV1AQF8 CP version: J330FXXU1AQFB Product code: XSG Phone SN: R58J82AV78E Unique number: CQE00CD0ACE1C64 Searching Samsung diag port... detected COM963 Reading phone info... OK CP version: J330FXXU1AQFB CP build: Jun 22 2017 23:18:49 Reading data from phone... error (1) Done with Samsung Tool PRO v.29.8 |
thanks Z3X team successful opertion Operation: Read Codes via Server Selected model: SM-J330F Software version: 29.8 Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM964 Reading phone info... OK Model: SM-J330F AP version: J330FXWU1AQF9 CSC version: J330FOJV1AQF8 CP version: J330FXXU1AQFB Product code: XSG Phone SN: R58J82AV78E Unique number: CQE00CD0ACE1C64 Searching Samsung diag port... detected COM963 Reading phone info... OK CP version: J330FXXU1AQFB CP build: Jun 22 2017 23:18:49 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 9740XXX NET lock: 7904XXXX SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.8 |
how did u solve this problem? |
your problem sloved |
my device brainy u3 and knox is 1 and i can not solve problem Reading data from phone... error (1) are u now how i can fix it best regards |
hello, show log of your job for begin. |
thats it Quote:
Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever ('Diag' algo): Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever ('Upload' algo): Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J330F Software version: 31.4 Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330F Android version: 7.0 PDA version: FA70_J330FXXU1AQF6 CSC version: Phone version: J330FXXU1AQEB Product code: SM-J330FZDDSER CSC country code: CSC sales code: Phone SN: R58JA638X7A IMEI: 353xxxxxxxxxxxx HW version: MP 0.500 RF cal date: 20171027 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-05-01 Boot Warranty bit: 1 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM31 detected Reading data from phone... error (1) Done with Samsung Tool PRO v.31.4 |
